Hi, I’m having some problem adding automation script with HA bridge
Using similar setup to this
The automation script is listed in homeassistant devices
However, nothing happens when I tried turning it on in ha bridge and broadlink device was not blasting ir signal at the same time.
The configuration is working fine as I can still use ifttt to trigger the channel automation or from the front end
Is there any anything else I need to configure properly with automation script?
So far it works fine with switch
