I have been strugggling with adding this unit using the Zigebee Home Automation integration at my cabin. I have another one installed at home, but I use Conbee Phoscon at home.
I have read other threads here that suggests holding button 1 ten seconds and then pressing button 2 and 3 together, if using channel 15 which I am.
I do however have no luck with this unit. I am also uncertain if this is what works with the Zigbee Home Automation integration. Some threads says that this is not implemented yet, but those threads are a bit aged.
What is the current status? Can I get this unit to work using the described setup? Do I have to be close to the conbee stick when doing this or is it sufficient that the device somewhere in the zigbee network’s range?
My HA (2023.10.4) is running in docker. My other zigbee devices works just fine. I have also tried replacing the batteries in the device.
