i have a script which i can execute from lovelace. i want this script to publish MQTT message, but only if an input_boolean is set to on.
is this possible with a script? if not what’s the alternative? i wish to have several operations in the sequence where each one is dependent of its own input_boolean.
Of course, the way a condition works is that if the condition isn’t met, the script stops. You can’t do a series of only do X if Y is set without the use of templating. There you’d pick a dummy topic to publish messages to if the boolean isn’t set.
isn’t there a simpler way to achieve this? adding automation for every operation will look terrible - i have many items in the sequence which all need to use conditions…
