Here’s my scenario:
I have a cable modem, provided by the cable service here in my country. It is connected by cable, to a router (lan port). My modem has DHCP enabled and the router has it disabled, in other words, even connected to the router, the modem is the one providing IP’s. So, all the devices connected have the same IP structure - 192.168.0.xx
Here’s what I did: My router was being used only as a bridge, none of its functions were being explored. So, I switched the cable to the wan port and then enabled the DHCP as well, having a second network (192.168.31.xx)… now I’m properly using the router with all its possibilities. Now I have modem with DHP, giving IP´s 192.168.0.xx and the router giving IPs 192.168.31.xx
Everything works fine… except my HA … all devices I need to write the IP address to the code (roborock S50, sonoffs, ip cameras), and if they are connected to the router, not the modem, I had to switch to 31.xx instead of 0.xx, all of them stopped working.
Is there any way to have HA integrated with this other sub-network I just created?
I wish I had the option to pick specific devices and choose the modem dhp, skiping router dhcp …
