I have added solar to my HA config.yml using a site API but im trying to feed this into the energy tab in HA. I have read alot of forums and the Docs but clearly missing something because they are not viable in the energy tab under solar. here is my config.yml info
platform: rest
resource: https://www.solaxcloud.com/proxyApp/proxy/api/getRealtimeInfo.do?tokenId=20211018174239611345102&sn=SWWVUTRCWC
value_template: “{{ ( value_json.result.yieldtotal | round(0) ) | float }}”
unit_of_measurement: “KWh”
device_class: “energy”
state_class: “total”
unique_id: “solax_total” -
platform: rest
value_template: “{{ ( value_json.result.acpower | round(0) ) | float }}”
unit_of_measurement: “W”
state_class: “total_increasing”
unique_id: “solax_now” -
platform: rest
resource: as above
value_template: “{{ value_json.result.yieldtoday | float }}”
unique_id: “solax_today” -
platform: rest
resource: as above
value_template: “{{ value_json.result.uploadTime }}”
name: “Solax upload time”
unique_id: “solax_upload_time” -
platform: template
sensors:
solax_total:
friendly_name: “Solax Total”
value_template: “{{ states(‘sensor.solax_total_raw’) | float | round(0) }}”
device_class: “energy”solax_total_raw:
friendly_name: “Solax Total (Raw)”
value_template: “{{ value_json.result.yieldtotal }}” -
platform: rest
resource: as above
value_template: >
{% if value_json.result.inverterStatus == ‘100’ %}Wait
{% elif value_json.result.inverterStatus == ‘101’ %}Check
{% elif value_json.result.inverterStatus == ‘102’ %}Normal
{% elif value_json.result.inverterStatus == ‘103’ %}Fault
{% elif value_json.result.inverterStatus == ‘104’ %}Permanent Fault
{% elif value_json.result.inverterStatus == ‘105’ %}Update
{% elif value_json.result.inverterStatus == ‘106’ %}EPS Check
{% elif value_json.result.inverterStatus == ‘107’ %}EPS
{% elif value_json.result.inverterStatus == ‘108’ %}Self-test
{% elif value_json.result.inverterStatus == ‘109’ %}Idle
{% elif value_json.result.inverterStatus == ‘110’ %}Standby
{% elif value_json.result.inverterStatus == ‘111’ %}Pv Wake Up Bat
{% elif value_json.result.inverterStatus == ‘112’ %}Gen Check
{% elif value_json.result.inverterStatus == ‘113’ %}Gen Run
{% else %}I dont know{% endif %}
unique_id: “solax_status”
please help
