First, I am still really new to using HA and finding my way around, so I’m sure I’m missing things and not finding the stuff I need. It’s quite possible I’m missing some obvious steps. I’m including whatever I can because I don’t know what’s significant and I’d rather have too much than not enough, so feel free to scan the parts that give needed info.
I’m running into trouble adding my first Z-Wave device. (I have some others that are currently hooked up to an ISY-994i. I don’t want to remove them from that network until I know I have things working and can replace the events I have setup for them on the ISY.)
I put the HAOS image on a USB drive and plugged that and an Aeotec Z-Stick 7 into a Pi4 and started it up, went through configuration, and when I added the Z-Stick (it wasn’t under the name Aeotec, but I can’t remember the name it was under), Z Wave JS got added, too. I think I have the Z-Stick set up:
So did I get that right and get the Z-Stick behaving and is there anything else I need to do to make sure I can add Z-Wave devices?
My first Z-Wave device is a Schlage lock. I’ve tried to add it several times. I go to Configuration->Integrations, find Z Wave JS, and click on Configure. On both the web interface and on my iPhone, I get:
From there, I click or touch “ADD NODE” and proceed without Secure Inclusion and touch/click on Start Inclusion. At that point I see a change on the “Start Inclusion” button, but that’s it, so I don’t know if there’s another step or if something is supposed to come up telling me it’s waiting for a device. That’s when I did what I needed to on the Schlage lock. I got the “Interviewing” dialog, but not long after that, the lock flashed the X, showing it failed.
I tried it again and got the same thing. HA was still interviewing the lock when the lock reported failure.
I may have tried it more times, I’m not sure. I now have a node_2 and node_3 listed under Z Wave JS and both are unavailable. I tried to remove node_2 and I see no result. I later tried to remove node_3 and got a message that it couldn’t be removed while something else was being removed. I found a switch to enable node_2, but HA now sees it as dead and there’s nothing I can do with it.
I can’t help but say, “What we have here is a failure to communicate.” It looks like HA/Z-Stick 7 see there’s something there, but are still “interviewing” it when the lock is saying, “Haven’t received the info I need to join the network, so it failed.”
I’m not sure whether to keep trying to remove the lock or to do something with it now. I did try re-interviewing it, and that’s done no good at all.
