after adding google calendar to HA
and restart i get google calendar setup notification
Error: Invalid response 401. Error: deleted_client
You will need to restart hass after fixing.
can somebody explain
what does it means
Refael
what does it means
Refael
can you share how you added Google Calendar? What’s your config? (hide email and password)
my configuration.yaml is
google:
client_id: xxxxxxxxxxxx.apps.googleusercontent.com
client_secret: _xxxxxxxxxxxx
now i looked and i dont have
google_calendars.yaml
maybe i didnt configure the API correctly in
Google Developers Console ?
whats the right way to configure
Refael
can you use the blue bar on top of the page to format your code correctly? At the moment I can’t see if there are indentation errors or not.
you should indeed have a google_calendars.yaml
file automatically created upon successful link/config.
If not you may want to review the setup steps in the doc again, sounds like you might have missed something
I’m going to break in here to ask a related question. I get this error at startup:
homeassistant.exceptions.HomeAssistantError: Entity id already exists: calendar.contacts
I’m using the atomic.calendar custom card, but don’t have the contacts calendar configured for the card. However, the contacts.calendar does appear in the google_calendars.yaml file.
- cal_id: '#[email protected]'
entities:
- device_id: contacts
ignore_availability: true
track: true
