Adding Homematic IP devices are not displayed in the Home Assistant
Hi Devs,
im running into an issue taht i’m stuggeling to add HMIP-Device into the HA.
I’m using the “HomeMatic OCCU” and configuration seems to work…
i followed the instruction : https://www.youtube.com/watch?v=G85kOZtt_Uk
but when i add an HMIP device i can see in the logs that some thing is happening…
2019-05-08 00:34:43,213 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: 0 Accesspoints in Queue
2019-05-08 00:34:43,214 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
2019-05-08 00:34:43,214 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: Eventlistener Handler utilization: 0/50 used
2019-05-08 00:37:54,960 [INFO] HMIPNetworkManagementHandler - AP 3014F711A000041709ADFA27: Device included 3014F711A0000197099890AF
but it’s not showing up in the entities list…
does anyone ahve a clou how i can investigate more ?
thanks
Viktor
bigger logfile:
2019-05-08 00:39:43,222 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: 0 Accesspoints in Queue
2019-05-08 00:39:43,223 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
2019-05-08 00:39:43,223 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: Eventlistener Handler utilization: 0/50 used
2019-05-08 00:44:43,221 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: 0 Accesspoints in Queue
2019-05-08 00:44:43,222 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
2019-05-08 00:44:43,222 [INFO] DeviceBackgroundUpdateSubsystem - SYSTEM: Eventlistener Handler utilization: 0/50 used
May 08, 2019 12:44:45 AM io.vertx.core.eventbus.impl.HandlerRegistration
SEVERE: Failed to handleMessage
de.eq3.cbcs.legacy.communication.rpc.RpcRemoteException: Error requesting method event: <class 'KeyError'>:'CENTRAL:0' Code: 1
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRpcParser.parseMethodResponse(XmlRpcParser.java:156)
at de.eq3.cbcs.legacy.communication.rpc.internal.format.xml.XmlRequestResponseProcessor.parseResponse(XmlRequestResponseProcessor.java:171)
at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:82)
at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.sendRequest(RpcClient.java:94)
at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.invoke(RpcClient.java:82)
at com.sun.proxy.$Proxy20.event(Unknown Source)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendClient.event(LegacyBackendClient.java:119)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendNotificationHandler.handleReceivedStatusData(LegacyBackendNotificationHandler.java:262)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendNotificationHandler.handleBackendNotification(LegacyBackendNotificationHandler.java:143)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendNotificationHandler.handle(LegacyBackendNotificationHandler.java:94)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendNotificationHandler.handle(LegacyBackendNotificationHandler.java:38)
at io.vertx.core.eventbus.impl.HandlerRegistration.deliver(HandlerRegistration.java:212)
at io.vertx.core.eventbus.impl.HandlerRegistration.handle(HandlerRegistration.java:191)
at io.vertx.core.eventbus.impl.EventBusImpl.lambda$deliverToHandler$3(EventBusImpl.java:505)
at io.vertx.core.impl.ContextImpl.lambda$wrapTask$2(ContextImpl.java:337)
at io.vertx.core.impl.TaskQueue.lambda$new$0(TaskQueue.java:60)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
May 08, 2019 12:44:45 AM io.vertx.core.impl.ContextImpl
SEVERE: Unhandled exception
I’m now a step further …
it seems that there is a pbroblem with the switsch HMIP-WRC2
If i try to add this one to the occu then it’s not working… other devices (HMIP-SWDM and HMIP-eTRV-B) they show up in HomeAsistant ant therefore a entitie is created propperly…
can someone else confirm or check this behavor…
