Seems like you could simply change this
# Create & Run container
docker_container = self.sys_docker.run(
self.image,
version=self.addon.version,
name=self.name,
hostname=self.addon.hostname,
detach=True,
init=True,
privileged=self.full_access,
ipc_mode=self.ipc,
stdin_open=self.addon.with_stdin,
network_mode=self.network_mode,
pid_mode=self.pid_mode,
ports=self.ports,
extra_hosts=self.network_mapping,
devices=self.devices,
cap_add=self.addon.privileged,
security_opt=self.security_opt,
environment=self.environment,
volumes=self.volumes,
tmpfs=self.tmpfs,
to this
self.image,
name=self.name,
detach=True,
init=True,
ipc_mode=self.ipc,
ports=self.ports,
tmpfs=self.tmpfs,
label=self.name
I’m not sure if self.name is the correct name though. It appears to be the name of the container. Either way, this is the section you’d be adding it to.
EDIT: Nevermind, It would might require more changes to the sys_docker.run command
