[Home Assistant Matter Server to commission a device directly]
Today I tried a Bluetooth adapter, but I think it is not compatible…
UGREEN Bluetooth Adapter 5.4 [CM748]
2024-10-28 08:24:07.387 (MainThread) ERROR [matter_server.server] Error doing task: Task exception was never retrieved
File "/usr/local/lib/python3.11/site-packages/matter_server/server/client_handler.py", line 214, in _run_handler
raise err
File "/usr/local/lib/python3.11/site-packages/matter_server/server/client_handler.py", line 197, in _run_handler
result = await result
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 456, in set_thread_operational_dataset
await self._chip_device_controller.set_thread_operational_dataset(dataset)
File "/usr/local/lib/python3.11/site-packages/matter_server/server/sdk.py", line 183, in set_thread_operational_dataset
threadOperationalDataset=bytes.fromhex(dataset),
ValueError: non-hexadecimal number found in fromhex() arg at position 2
2024-10-28 08:26:35.865 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 1.
2024-10-28 08:26:35.985 (Dummy-2) CHIP_ERROR [chip.native.DL] Disabling CHIPoBLE service due to error: src/platform/Linux/BLEManagerImpl.cpp:596: Ble Error 0x00000401: BLE adapter unavailable
2024-10-28 08:26:35.985 (Dummy-2) CHIP_ERROR [chip.native.CTL] Commissioning discovery over BLE failed: src/platform/Linux/BLEManagerImpl.cpp:743: Ble Error 0x00000401: BLE adapter unavailable
2024-10-28 08:26:35.987 (Dummy-2) CHIP_ERROR [chip.native.-] src/platform/Linux/BLEManagerImpl.cpp:743: Ble Error 0x00000401: BLE adapter unavailable at src/controller/SetUpCodePairer.cpp:324
2024-10-28 08:26:35.987 (Dummy-2) CHIP_ERROR [chip.native.DL] Long dispatch time: 108 ms, for event type 3
2024-10-28 08:27:05.884 (Dummy-2) CHIP_ERROR [chip.native.CTL] Discovery timed out
2024-10-28 08:27:05.884 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2024-10-28 08:27:05.885 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:89: CHIP Error 0x00000003: Incorrect state
2024-10-28 08:27:05.885 (MainThread) ERROR [matter_server.server.client_handler] [140417963409104] Error while handling: commission_with_code: Commission with code failed for node 1.
2024-10-28 08:28:22.775 (MainThread) ERROR [matter_server.server] Error doing task: Task exception was never retrieved
raise err
2024-10-28 08:29:00.643 (MainThread) ERROR [matter_server.server] Error doing task: Task exception was never retrieved
raise err
ValueError: non-hexadecimal number found in fromhex() arg at position 0
2024-10-28 08:29:25.915 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 2.
2024-10-28 08:29:25.921 (Dummy-2) CHIP_ERROR [chip.native.CTL] Commissioning discovery over BLE failed: src/platform/Linux/BLEManagerImpl.cpp:743: Ble Error 0x00000401: BLE adapter unavailable
2024-10-28 08:29:25.921 (Dummy-2) CHIP_ERROR [chip.native.-] src/platform/Linux/BLEManagerImpl.cpp:743: Ble Error 0x00000401: BLE adapter unavailable at src/controller/SetUpCodePairer.cpp:324
2024-10-28 08:29:55.928 (Dummy-2) CHIP_ERROR [chip.native.CTL] Discovery timed out
2024-10-28 08:29:55.929 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2024-10-28 08:29:55.929 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:89: CHIP Error 0x00000003: Incorrect state
2024-10-28 08:29:55.930 (MainThread) ERROR [matter_server.server.client_handler] [140417963409040] Error while handling: commission_with_code: Commission with code failed for node 2.
On the other hand, when starting the process it asks for the “Dataset ID” of the Thread network, when is it really referring to the Extended Pan ID?
Using “Dataset id” show error:
Error setting Thread dataset: non-hexadecimal number found in fromhex() arg at position 2
NOTE: The first time you set the property to 1, it is reset to 0
Settings ->Add-ons → Matter Server → Configuration I then set the Bluetooth Adapter ID to 1
