I am using presence detection with Life360 and it is working very well, see Lovelace card attached.
I’d like to add mdi icons based on each person’s location so for example if home show a house icon. I have defined the icons in the zone setup in my configuration.yaml file - work, gym etc…
Any help would be greatly appreciated.
You can’t do what you want with the native card. You’d have to get inventive with custom cards to have the desired setup.
maybe nt what you are looking for, but my family is displayed with entity_pictures based on their zone.
Does take the effort to create these manually, and then use a setup using this template:
- type: custom:button-card
template: button_picture_family
entity: device_tracker.life360_name
entity_picture_template: >
if (entity.state === 'home' || entity.state === 'not_home') return '/local/tiles/family/name_' + entity.state + '.png';
return '/local/tiles/family/name_' + states['sensor.name_location_picture'].state + '.png';
tap_action:
entity: group.name
of course replace ‘name’ in the sensors above with the actual name of the person.
the button template takes care of the background color:
home = green, not_home (and not in a zone) = grey, in a zone (life360) purple:
button_picture_family:
show_state: false
show_label: false
show_name: false
show_entity_picture: true
color_type: card
aspect_ratio: 1/1
tap_action:
action: more-info
haptic: light
hold_action:
action: more-info
haptic: success
styles:
card:
- border-radius: 6px
- box-shadow: '0px 0px 2px 1px #F0C209'
entity_picture:
state:
- operator: template
value: >
return entity.state === 'home'
color: '#008000'
value: >
return entity.state === 'not_home'
color: '#555B65'
- operator: default
color: '#643aac'
see What does your deafult page look like? for an (edited) image
Great will give this a try.
Thanks!
Here’s another way to do it with a template sensor. It grabs the icon from the zone.
presense_dan_icon:
friendly_name: "Dan"
value_template: "{{ states('person.dan') }}"
icon_template: >
{{ states.zone | selectattr("attributes.friendly_name","equalto",states("person.dan"))|map(attribute="attributes.icon")|first }}
Also worth doing something about the state entity showing ‘home’ or ‘not_home’.
Not sure which method below I prefer. The last works in all scenarios but seems like too much code.
If anyone has a clever solution please reply.
Shortest but won’t work for zones that you don’t want title cased:
{{ states('person.dan')|replace("_"," ")|title }}
A bit longer, but doesn’t work if you have a zone that needs the word ‘home’ to stay in lowercase.
{{ states('person.dan')|replace("home","Home")|replace("not_home","Not Home") }}
or the longest way that I believe will work 100% of the time
{% if states('person.dan') == 'home' %}
Home
{% elif states('person.dan') == 'not_home' %}
Not Home
{% else %}
{% endif %}
Hi
could you let me know where the “button_picture_family:” has to be put in the configuration ?
its a button-card-template and here’s the documentation on that: GitHub - custom-cards/button-card: ❇️ Lovelace button-card for home assistant
