I’m not sure if what I’m attempting to do is possible or not.
I’m using hassio (or whatever it’s called now), running perfectly well in a VM. Integration wise, I’m successfully using zigbee2mqtt and some other integrations for various plugs like tp-link and an integration for tado thermostats.
So far I’ve set up everything via the UI, and I’ve been using node-red for automations etc.
I was playing with mqtt, with the idea that I could make something to show the state of switches etc in another location, like the garage or whatever.
To test, I’m using MQTT Explorer and I can see the state of my various zigbee switches and lights.
This is when I noticed that the state of the other devices are not published over mqtt. For example a tp-link plug.
So finally, my question is, can I expose my other devices over mqtt?
edit
A thought just came to me, perhaps I’m looking at this the wrong way, and I should use restful api to obtain the state of my switches etc?
Best regards,
Wayne
