Hi there. I am measuring the power the power that my QNAP NAS is consuming, and noticed that is not going into standby mode anymore. Usually when no one is connecting to the SMB shares, the QNAP stops the disks which brings down power consumption from 50w to around 24w.
Untill now, I was unable to determine since when the QNAP stopped going into standby.
I have a SMB share on my NAS configured as Home Assistant network storage. I only use it to create Home Assistant backups to this share. I found out that Home Assistant somehow is periodically checking if that SMB share is still available (it looks like roughly every 10 min), and this prevents my NAS from going into sleep. After removing the network storage from HA the problem is immediatly solved and the QNAP goes into sleep.
Is there a reason for this keep alive?
Like to hear your opinion.
