Dear Community,
I am looking for your help. I am new to Home Assistant. Just about 2 months of experience, but learning fast.
I have an issue with adding new device to zigbee2mqtt. I have bought TuYa TRV
( https://www.made-in-china.com/showroom/misslinda821/product-detailINumhMclhRVL/China-Saswell-Tuya-Smart-Zigbee-Trv-Amazon-Alexa-and-Google-Assistance-Voice-Control-Available-Room-Thermostat.html ) which is not supported to date.
I am trying to follow documentation about adding new devices, but it seems not to work for me.
What I did?
So I set up debug logs in zigbee2mqtt configuration:
advanced:
log_level: debug
I have put it also in zigbee2mqtt configuration (~/share/zigbee2mqtt/ folder/configuration.yaml)
zigbee_shepherd_devices: true
since I am trying to use sheppard mode :
I have the newest zigbee2mqtt installed so I have copied https://github.com/Koenkk/zigbee-herdsman-converters/blob/f89377f299da70a29ac70d1b26846e87d44a2af4/devices.js from master branch into my ~/share/zigbee2mqtt/ folder
Since I think this new TRV is mostlikely the evolution of TuYa TS0601_thermostat I have added following rows to my local devices.js ( in ~/share/zigbee2mqtt/ folder).
This is what I put there (I copied it from other similat model:zigbeeModel: [‘kud7u2l’],:
zigbeeModel: [‘88teujp’],
fingerprint: [{ modelID: ‘TS0601’, manufacturerName: ‘_TTYST11_c88teujp’ }],
model: ‘TS0601_thermostat’,
vendor: ‘TuYa’,
description: ‘Radiator valve with thermostat’,
supports: ‘thermostat, temperature’,
whiteLabel: [
{ vendor: ‘Moes’, model: ‘HY369RT’ },
{ vendor: ‘SHOJZJ’, model: ‘378RT’ },
meta: { tuyaThermostatSystemMode: common.TuyaThermostatSystemModes, tuyaThermostatPreset: common.TuyaThermostatPresets },
fromZigbee: [fz.tuya_thermostat, fz.tuya_thermostat_on_set_data, fz.ignore_basic_report],
toZigbee: [
tz.tuya_thermostat_child_lock, tz.tuya_thermostat_window_detection, tz.tuya_thermostat_valve_detection,
tz.tuya_thermostat_current_heating_setpoint, tz.tuya_thermostat_system_mode, tz.tuya_thermostat_auto_lock,
tz.tuya_thermostat_calibration, tz.tuya_thermostat_min_temp, tz.tuya_thermostat_max_temp,
tz.tuya_thermostat_boost_time, tz.tuya_thermostat_comfort_temp, tz.tuya_thermostat_eco_temp,
tz.tuya_thermostat_force, tz.tuya_thermostat_preset,
toZigbee: [
Unfortunately, it does not work. I do not see any difference in the zigbee2mqtt logs……
I HAVE AN IMPRESSION DEVICES.JS I CREATED IS NOT READ.
In logs file I still see
Zigbee2MQTT:warn 2020-10-03 11:44:57: Received message from unsupported device with Zigbee model ‘88teujp’
Zigbee2MQTT:warn 2020-10-03 11:44:57: Please see: https://www.zigbee2mqtt.io/how_tos/how_to_support_new_devices.html.
and during manipulation on device:
Zigbee2MQTT:debug 2020-10-03 11:49:01: Received Zigbee message from ‘0x60a423fffe8cf958’, type ‘commandGetData’, cluster ‘manuSpecificTuyaDimmer’, data ‘{“data”:{“data”:[0,0,0,50],“type”:“Buffer”},“dp”:615,“fn”:0,“status”:0,“transid”:3}’ from endpoint 1 with groupID 0
Zigbee2MQTT:warn 2020-10-03 11:49:01: Received message from unsupported device with Zigbee model ‘88teujp’
Zigbee2MQTT:warn 2020-10-03 11:49:01: Please see: https://www.zigbee2mqtt.io/how_tos/how_to_support_new_devices.html.
Zigbee2MQTT:debug 2020-10-03 11:49:01: Received Zigbee message from ‘0x60a423fffe8cf958’, type ‘commandGetData’, cluster ‘manuSpecificTuyaDimmer’, data ‘{“data”:{“data”:[1],“type”:“Buffer”},“dp”:357,“fn”:0,“status”:0,“transid”:1}’ from endpoint 1 with groupID 0
Please help.
I would like also to ask for a help with adding support for this device officially in add-on.
I am happy to make a pull request if all works for me and create documentation for it.
Thank you in advance.
Here is my log.
Device ID is 0x60a423fffe8cf958
