I am trying to add a floor plan photo to my dashboard.
I have my HA installed in raspberry pi 4.
I have a photo png. In my iPad . I used file editor add on to put the photo under www
When I open the picture card l change the path to /local/home.png but the pictures doesn’t show up.
The link to the photo can open on the web browser but it doesn’t work in home assistant dashboard
Any help please .
Omit the first slash:
image: local/home.png
Did you restart Home Assistant after creating the config/www folder?
I have been making restart for HA several times. Also after adding the photo I do restart but it doesn’t help
You need the full URL. See https://www.home-assistant.io/integrations/http#hosting-files
local/<img> should work. Have you double-checked the file ending? Is it actually .png?
Also the filename is case sensitive.
Unfortunately it didn’t work with
http://my local/local/home.png.
Any Help to start from scratch for example ? I also tried to put the url link for the pic in cloud.
Is there any problem , because I noticed also that I can’t open links with https ( which is an other problem
http://my local
/local/home.png
Again: Have you checked the www folder if home.png really is home.png and not home.PNG or 4015C79F-2EEF-4FB0-A297-24EF3ACD2F89.png or anything else?
Is the image in www or a subfolder of www?
If the file name is correct, empty your browser cache and login again.
I opened the picture that I put under local.png then I copied the link in the browser and this was a long one🙂
http://homeassistant.local:8123/api/hassio_ingress/ChlUiI7-uU2eq_M7ihU4rWyIbIdLLGKFyKAJYJvMna8/api/file?filename=/config/www/Home.png
Then I copied this link in the card and it worked. Thank you
But why it didn’t using the file name. Anyway it’s working now
This is your problem:
The file is called Home.png. You used home.png.
local/Home.png should work.
Thank you very much. You are right. It’s my mistake.
I tried with
local/Home.png
It worked
In my case it works fine when using “/” before “local” …
- type: picture
image: /local/folder_name/picture_name.jpg
Please don’t bump 10 month old solved topics with unrelated information.
Do a question to be complete … ho do you transfer / put the file in the www folder ?
I have the picture on my computer … ha is running on my NAS (Virtual machine). Is there a way, from the HA interface, to take a picture from the computer (import) ?
many Thanks !
Use the SAMBA share addon to transfer the file to config/www.
Hello Team,
I encountered an issue while attempting to add a floor plan photo to my Home Assistant dashboard. Despite placing the PNG file in the ‘www’ directory using the file editor add-on and specifying the correct path (/local/home.png) for the picture card, the image fails to display on the dashboard. The link to the photo is accessible in a web browser, but it doesn’t render within the Home Assistant dashboard. Any assistance would be appreciated. Additionally, if you enjoy working with photos, you might find value in exploring features offered by PicsArt Gold…Good Thought.
Best of Luck.
Additionally, if you enjoy working with photos, you might find value in exploring features offered by Pixellab photo editor app. It’s a fantastic tool for photo editing with a wide range of features that can help you create stunning visuals. Good thought!
I’m having trouble adding a floor plan photo to my Home Assistant dashboard. I put the PNG file in the ‘www’ folder using the file editor add-on and used the path /local/home.png for the picture card, but the image doesn’t show up on the dashboard. I can access the photo through a web browser, but it won’t display on the dashboard. Any help would be great!
Also, if you enjoy games like Dude Theft Wars Apk, you might find it fun to explore its features. It’s an entertaining game with a lot of creative possibilities!
