Where/how can i add resources: when im editing my lovelace with its own ui editor ?
Also, is there a way to resize some cards, like that huge thermostat card ?
From a post on the Discord server:
I’ve confirmed that
resources
are indeed being removed on save in the front-end when using Raw Config Editor on the UI in 0.85. I recommend holding off till 0.85.1 if you haven’t already upgraded until we know more.
Hold off until 0.85.1, or switch to YAML mode.
For resizing cards, there’s not currently any way to say “make it this size”. They all default to the same width unless you’re using Panel mode.
Ty, complete answer
