Adding Skyconnect to a VM HA
I am running a proxmox-ve server and my VM running HA.
I see my Skyconnect on the host:
Code:
 usb 4-2: new full-speed USB device number 2 using uhci_hcd
[377754.484965] usb 4-2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[377754.484980] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[377754.484984] usb 4-2: Product: SkyConnect v1.0
[377754.484987] usb 4-2: Manufacturer: Nabu Casa
[377754.484989] usb 4-2: SerialNumber: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[377754.612707] usbcore: registered new interface driver usbserial_generic
[377754.612733] usbserial: USB Serial support registered for generic
[377754.625648] usbcore: registered new interface driver cp210x
[377754.625671] usbserial: USB Serial support registered for cp210x
[377754.625710] cp210x 4-2:1.0: cp210x converter detected
[377754.630203] usb 4-2: cp210x converter now attached to ttyUSB0
But when starting to configure, on my HA, the Zigbee integration, I have 5 differents choices of possible Radio type, when choosing EZSP and as Serial Device Path: /dev/ttyUSB0 … I have a failed to connect.
Did you ‘pass-through’ the stick from proxmox to HA ?
yes of course :slight_smile:
Capture d'écran 2024-04-16 163715
Use /dev/serial/by-id/…
Is it /dev/serial or /dev/disk because I do not have any serial …
Thx
Then your Skyconnect is not properly recognised in the VM
