Image courtesy of wikipedia.
I’ve seen a few people who’ve integrated into the cloud based API of the Seneye system before. The problem with this is it involves either having to keep a M$ PC running the Seneye Connect app or spending 2-3 times as much money to pick up the Seneye Web Server or Web Server WiFi, as well as the Seneye sensor…well I had a better idea.
First up I wanted to write a native Python driver for the Seneye USB Device (SUD). The manufacturer released some sample code, in C++ and C# along with some accompanying docs of the underlying message structures…these left a lot to be desired but were a good place to start. I won’t go into too much detail but some late nights and lot’s of frustration with the bugs/gaps in the manufacturers documentation lead to this python module, pyseneye.
I’d like to add support for this base into HA, eventually but as an initial step I wanted to implement a custom component. The code for that is on github, here. I’ve currently implemented pH, NH3 and temp as a POC. I’ll be adding results for light readings shortly. The readings are throttled to once every 30 mins, as per Seneyes recommendations, which is why the code is slightly more complex than I initially thought it would be.
The result
When using the Seneye via HA, you won’t get your results synced up to the Seneye.me platform so you will need to implement alerts with Twilio or your favorite notifications platform, to get the similar functionality. The USB interface has a flag to say if the pH/NH3 slide is expired, which I’m currently ignoring…what will be interesting is to see if the readings still come back after the expiry time. I only wrote the driver and the component in the last week, so testing has been minimal so far but it would be good to get some early feedback.
The configuration is as easy as it gets:
- platform: seneye
The up-to-date code is on [Github]https://github.com/mcclown/home-assistant-custom-components/blob/master/seneye/sensor.py) but for a quick skim, it’s below.
Support for the Seneye range of aquarium and pond sensors.
For more details about this platform, please refer to the documentation at
This custom component is based on the Awair component in HA.
https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/sensor/awair.py
from datetime import timedelta
import logging
from homeassistant.const import DEVICE_CLASS_TEMPERATURE, TEMP_CELSIUS
from homeassistant.exceptions import PlatformNotReady
from homeassistant.helpers.entity import Entity
from homeassistant.util import Throttle, dt
REQUIREMENTS = ['https://github.com/mcclown/pyseneye/archive/0.0.1.zip#pyseneye==0.0.1']
_LOGGER = logging.getLogger(__name__)
ATTR_TIMESTAMP = 'timestamp'
ATTR_LAST_SLIDE_READ = 'last_slide_update'
ATTR_SENEYE_DEVICE_TYPE = 'seneye_device_type'
DEVICE_CLASS_PH = 'PH'
DEVICE_CLASS_FREE_AMMONIA = 'NH3'
UNIT_POWER_OF_HYDROGEN = 'pH'
UNIT_PARTS_PER_MILLION = 'ppm'
SENSOR_TYPES = {
'temperature': {'device_class': DEVICE_CLASS_TEMPERATURE,
'unit_of_measurement': TEMP_CELSIUS,
'icon': 'mdi:thermometer'},
'ph': {'device_class': DEVICE_CLASS_PH,
'unit_of_measurement': UNIT_POWER_OF_HYDROGEN,
'icon': 'mdi:alpha-h-box-outline'},
'nh3': {'device_class': DEVICE_CLASS_FREE_AMMONIA,
'unit_of_measurement': UNIT_PARTS_PER_MILLION,
'icon': 'mdi:alpha-n-box-outline'}
SCAN_INTERVAL = timedelta(minutes=5)
SENEYE_SLIDE_READ_INTERVAL = timedelta(minutes=30)
async def async_setup_platform(hass, config, async_add_entities,
discovery_info=None):
"""Setup Seneye objects"""
try:
seneye_data = SeneyeData(SENEYE_SLIDE_READ_INTERVAL)
await seneye_data.async_update()
all_sensors = []
for sensor in SENSOR_TYPES:
if sensor in seneye_data.data:
seneye_sensor = SeneyeSensor(seneye_data, sensor, SENEYE_SLIDE_READ_INTERVAL)
all_sensors.append(seneye_sensor)
async_add_entities(all_sensors, True)
return
except Exception as e:
_LOGGER.error("Error: {0}".format(e))
raise PlatformNotReady
class SeneyeSensor(Entity):
"""Implementation of a Seneye sensor."""
def __init__(self, data, sensor_type, throttle):
"""Initialize the sensor."""
self._device_class = SENSOR_TYPES[sensor_type]['device_class']
self._name = 'Seneye {}'.format(self._device_class)
unit = SENSOR_TYPES[sensor_type]['unit_of_measurement']
self._unit_of_measurement = unit
self._data = data
self._type = sensor_type
self._throttle = throttle
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def device_class(self):
"""Return the device class."""
return self._device_class
@property
def icon(self):
"""Icon to use in the frontend."""
return SENSOR_TYPES[self._type]['icon']
@property
def state(self):
"""Return the state of the device."""
return self._data.data[self._type]
@property
def device_state_attributes(self):
"""Return additional attributes, preprocess before returning."""
raw_dt = self._data.attrs[ATTR_LAST_SLIDE_READ]
# Convert timestamp to local time, then format it.
local_dt = dt.as_local(raw_dt)
formatted_dt = local_dt.strftime("%Y-%m-%d %H:%M:%S")
seneye_device_type = self._data.attrs[ATTR_SENEYE_DEVICE_TYPE]
return {ATTR_LAST_SLIDE_READ: formatted_dt,
ATTR_SENEYE_DEVICE_TYPE: seneye_device_type}
@property
def available(self):
"""Device availability based on the last update timestamp.
Data should be updating every 30mins, so we'll say it's unavailable
if it takes over an hour to update.
if ATTR_LAST_SLIDE_READ not in self._data.attrs:
return False
last_api_data = self._data.attrs[ATTR_LAST_SLIDE_READ]
return (dt.utcnow() - last_api_data) < (2 * self._throttle)
@property
def unique_id(self):
"""Return the unique id of this entity."""
return "seneye_{}".format(self._type)
@property
def unit_of_measurement(self):
"""Return the unit of measurement of this entity."""
return self._unit_of_measurement
async def async_update(self):
"""Get the latest data."""
await self._data.async_update()
class SeneyeData:
"""Get data from Seneye device."""
def __init__(self, throttle):
"""Initialize the data object."""
self.data = {}
self.attrs = {}
self.async_update = Throttle(throttle)(self._async_update)
async def _async_update(self):
"""Get the data from SUD."""
from pyseneye.sud import SUDevice, Action, DeviceType
device = SUDevice()
device_type = None
resp = None
try:
data = device.action(Action.ENTER_INTERACTIVE_MODE)
device_type = data.device_type.name
resp = device.action(Action.SENSOR_READING)
if not resp:
return
finally:
device.close()
self.attrs[ATTR_LAST_SLIDE_READ] = dt.utcnow()
self.attrs[ATTR_SENEYE_DEVICE_TYPE] = device_type
self.data[sensor] = getattr(resp, sensor, None)
_LOGGER.debug("Got Seneye data")
