Adding support for some new Tuya Devices to ZHA [New Devices]
Hi All
Wondering if someone can help please.
A few new devices trying to add to ZHA for testing
First one a PIR from Coolcam
  "node_descriptor": "<NodeDescriptor byte1=2 byte2=64 mac_capability_flags=128 manufacturer_code=0 maximum_buffer_size=82 maximum_incoming_transfer_size=255 server_mask=11264 maximum_outgoing_transfer_size=255 descriptor_capability_field=0>",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0x0000",
      "in_clusters": [
        "0x0000",
        "0x0003"
      "out_clusters": [
        "0x0003",
        "0x0019"
  "manufacturer": "_TYST11_7hfcudw5",
  "model": "hfcudw5",
  "class": "zigpy.device.Device"
Second one a powerboard from Jinvoo, a zigbee version of their wifi powerboard
  "node_descriptor": "<NodeDescriptor byte1=1 byte2=64 mac_capability_flags=142 manufacturer_code=4098 maximum_buffer_size=82 maximum_incoming_transfer_size=82 server_mask=11264 maximum_outgoing_transfer_size=82 descriptor_capability_field=0>",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0x0009",
      "in_clusters": [
        "0x0000",
        "0x0004",
        "0x0005",
        "0x0006",
        "0x000a"
      "out_clusters": [
        "0x0019"
    "2": {
      "profile_id": 260,
      "in_clusters": [
        "0x0004",
        "0x0005",
        "0x0006"
      "out_clusters": []
    "3": {
      "profile_id": 260,
      "in_clusters": [
        "0x0004",
        "0x0005",
        "0x0006"
      "out_clusters": []
    "4": {
      "profile_id": 260,
      "in_clusters": [
        "0x0004",
        "0x0005",
        "0x0006"
      "out_clusters": []
    "7": {
      "profile_id": 260,
      "in_clusters": [
        "0x0004",
        "0x0005",
        "0x0006"
      "out_clusters": []
  "manufacturer": "_TYZB01_vkwryfdr",
  "model": "TS0115",
Third one a water sensor from Coolcam
  "endpoints": {
    "1": {
      "profile_id": 260,
      "in_clusters": [
        "0x0000",
        "0x0003"
      "out_clusters": [
        "0x0003",
        "0x0019"
  "manufacturer": "_TYST11_qq9mpfhw",
  "model": "q9mpfhw",
Fourth one a Siren from Coolcam
  "endpoints": {
    "1": {
      "profile_id": 260,
      "in_clusters": [
        "0x0000",
        "0x0003"
      "out_clusters": [
        "0x0003",
        "0x0019"
  "manufacturer": "_TYST11_d0yu2xgi",
  "model": "0yu2xgi",
@Adminiuga- what is the preferred way of requesting new integrations?
I bought the Jinvoo ZigBee PowerStrip but is not being recognized by ZHA.
Do you know if the devices you proposed were added to ZHA?
Thanks!
My powerstrip works fine. The others no.
What issues are you having with your powerstrip.
Do me a favour and and try and add it as a wifi device.
One on the first two they sent me was wifi even though the part number said it was zigbee. They had to send me another one. I have three off them and they have been rock solid.
I tried to register by WiFi but it didn’t work at all.
Is the one you have similar to this?
Thanks!
Finally it worked as a zigbee device but I don’t know why (I made several changes in between).
Thanks!
FYI, https://github.com/home-assistant/core/pull/60920 pull request for https://community.home-assistant.io/t/zha-integration-to-use-siren-entity-platform-for-zigbee-sirens-doorbells-and-chimes/343075 made into the 2021.21 release so if your device is not seen as a siren (even after remove and re-join it) then it need that specific device will probably need a custom quirk in ZHA Device Handlers, see → https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
Also see https://community.home-assistant.io/t/zha-integration-to-use-siren-entity-platform-for-zigbee-sirens-doorbells-and-chimes/343075
