I have a Aqara hub, set up on Mi Hi Home china verision.
I have configured water leak sensor, gas, smoke and a double rokete switch attached to the gateway.
Integrtion is displaing only light and alarm control.
On logs i found:
Logger: miio.gateway.gateway
Source: components/xiaomi_miio/gateway.py:126
First occurred: 01:09:13 (3 occurrences)
Last logged: 01:09:13
* Unknown subdevice discovered, could not match zigbee_model 'lumi.ctrl_neutral2.v1' of subdevice sid 'lumi.158d00032dabc9' from Xiaomi gateway with ip: 192.168.1.5
* Unknown subdevice discovered, could not match zigbee_model 'lumi.sensor_smoke.v1' of subdevice sid 'lumi.158d0003584851' from Xiaomi gateway with ip: 192.168.1.5
* Unknown subdevice discovered, could not match zigbee_model 'lumi.sensor_natgas.v1' of subdevice sid 'lumi.158d00035afb95' from Xiaomi gateway with ip: 192.168.1.5
Installed python-miio-0.5.12 and runing miiocli cloud
i got:
= Gateway (Device online ) =
Model: lumi. gateway.aqhm01
Token: -------------
IP: ------------ (mac: --------------------)
DID: ---------------
Locale: cn, de, sg
Sub devices:
Aqara Wall Switch (No Neutral, Double Rocker)
DID: lumi. 158d00032dabc9
Model: lumi.ctrl_neutral2.v1
Main Door Sensor
DID: lumi.158d0003f1b3f1
Model: lumi.sensor_magnet.aq2
Mi Smart Smoke Detector
DID: lumi.158d0003584851
Model: lumi.sensor_smoke.v1
Mi Smart Natural Gas Detector
DID: lumi.158d00035afb95
Model: lumi. sensor_natgas.v1
Water Leak Sensor
DID: lumi. 158d0004448d93
Model: lumi. sensor_wleak.aql
Water Leak Sensor
DID: lumi. 158d000460483f
Model: lumi. sensor_wleak.aq1
Motion sensor
DID: lumi. 158d000423c1a4
Model: lumi. sensor_motion. aq?
