I’ve successfully created a new custom sensor to return the maximum output value of my Solar PV system each day (this resets at midnight) using the script below, however, I would like to add the timestamp to the output entity i.e. hour, minutes and seconds in a 24hr format. How would I do this?
New Sensor setup Max solar house roof
platform: time
at: ‘00:00:00’
platform: state
entity_id: sensor.3_house_roof_solar_power
name: ‘Solar House Daily Max’
unique_id: ‘Solar_house_daily_max’
unit_of_measurement: ‘W’
device_class: power
state: >
{% set t_new = states(‘sensor.3_house_roof_solar_power’) | float(-50) %}
{{ [t_new, this.state | float(-50)] | max if trigger.platform != ‘time’ else t_new }}
Thanks for responding. Apologies, not sure why my original post was not formatted correctly. I’m looking for the timestamp to be included in the state, but it would be good to know how to show as a attribute too. .
If you do that then you will get an error message. Why? Because you have specified unit_of_measurement which means the state value must be numeric. Adding time as hh:mm:ss to the state value will make it non-numeric.
That’s why the example I posted puts the timestamp in an attribute, not in the state.
