Hi
Wanting to add some more info to the weather widget, as it is a bit plain
id like to add the town that the weather is showing for perhaps, or some better pictures? can anyone assist
Hi
adding the town is only possible if you have the town shown in Home assistant.
if you want to make changes like that then you need to make a custom widget.
so you need to copy the dir baseweather and the file weather.yaml to your conf directory.
and from that moment on you can start to edit those files
