Adding trigger based template to a templates.yaml file?
I’m trying to add a trigger based template to an included templates.yaml file. In my configuration it looks like:
template: !include templates.yaml
and in templates.yaml I have:
binary_sensor:
  - name: 'Both Home'
    unique_id: both_home
  - name: 'House Power Demand'
    unique_id: house_power_demand
    icon: mdi:transmission-tower
But when I add:
  - trigger:
    - platform: mqtt
      topic: "birdnet"
    - platform: time
      at: "00:00:00"
      - unique_id: new-sequence-12345678
I get an error:
Invalid config for 'template' at templates.yaml, line 217: required key 'platform' not provided
(line 217 is the -trigger line)
I’ve tried other various formations (including starting with -trigger), but no joy. I’m not sure where to go from here - how can I add trigger based templates to an included templates.yaml file?
Thanks for any clues.
trigger:   <----- remove this line
  - trigger: <----- keep this line
    - platform: mqtt
      topic: "birdnet"
    - platform: time
      at: "00:00:00"
From the documentation:
That doesn’t work, It seems like the documentation doesn’t translate for a separated templates file. I get the following:
2024-04-16 12:22:02.075 ERROR (MainThread) [homeassistant.config] Invalid config for 'template' at templates.yaml, line 216: 'trigger' is an invalid option for 'template', check: sensor->40->trigger
Invalid config for 'template' at templates.yaml, line 216: required key 'state' not provided
Invalid config for 'template' at templates.yaml, line 222: 'sensor' is an invalid option for 'template', check: sensor->40->sensor
the indenting looks like this:
binary_sensor:
  - name: 'Both Home'
  - trigger:
    - platform: mqtt
      topic: "birdnet"
    - platform: time
      at: "00:00:00"
if I adjust the indenting to the left, so that -trigger is “top level” in the file, I get:
2024-04-16 12:25:56.892 ERROR (MainThread) [homeassistant.components.template] while parsing a block mapping
  in "templates.yaml", line 1, column 1
expected <block end>, but found '-'
  in "templates.yaml", line 216, column 1
If someone has a working chunk of yaml for trigger based templates, in a separate file, I would love to see it. Thanks.
OK, I figured it out. Although this is acceptable, in isolation:
binary_sensor:
  - name: 'Both Home'
I needed to reformat to:
- binary_sensor:
  - name: 'Both Home'
- sensor:
to allow adding:
- trigger:
  - platform: mqtt
    topic: "birdnet"
  - platform: time
    at: "00:00:00"
Well that’s plainly wrong. Compare it to the screenshot I posted.
That’s exactly what I had suggested; once again, see the screenshot (above) sourced from the documentation. It’s the Solution.
Yes, for some reason I had it in my mind, that once moving to a separate file, you dropped the array ‘-’ part - I struggled with that when splitting my configuration files. Anyway - I’ve learned something new, and it’s all for the better.
Thanks for your help.
You’re welcome!
Please consider marking my post above with the Solution tag, given that it demonstrated what was needed to correct the error you had reported.
For more information about the Solution tag, refer to guideline 21 in the FAQ.
I’m trying to do similar. Although the code validates and saves OK, it doesn’t seem to work. The sensor section appears to work in Developer tools, it’s the trigger that doesn’t seem to evaluate the entity. Their states remain as ‘unknown’.
   - trigger:
     - platform: time
       at: "23:59:50"
       - name: "Greenhouse Heater Energy"
         unit_of_measurement: "kWh"
         device_class: energy
         state: >
            {% set greenhouse_daily_energy = states('sensor.shellyheater_daily_energy') %}
       - name: "Daily Gas Consumption"
         unit_of_measurement: "m³"
         device_class: gas
         state: >
            {% set gas_daily_consumption = states('sensor.current_accumulative_consumption_m3') %}
Your templates aren’t outputting anything.
Jinja uses various delimiters in the template strings.
{% %} - statements, these do not output anything.
{{ }} - expressions to print to the template output.
{# #} - comments which are not included in the template output, they also do not execute statements.
Adding a - after a starting delimiter will remove previous whitespace. Adding a - before an ending delimiter will remove trailing white space.
e.g.
{%- removes leading white space before a statement
-}} removes trailing white space after an expression that prints to the template output
Thanks for replying. Sorry I can’t format the code correctly (Edited to correct).
I was expecting the end of day values of the two sensors to be saved as two entities. I can add the curly brakets to output their values in Developer tools OK.
To format code, use 3 backticks before and after the code block.
` is a backtick.
On american keyboards, it shares the same button with ~ (tilda)
e.g.
This was also my thought and the reason why I found this thread who help me to found the solution!
Hello I am having a hard time getting my Trigger-Based template sensor to work. The Check Configuration always fails. Below are snippets from my configuration.yaml file and the template sensor file (template_trigger_based_sensors.yaml)
CONFIGURATION.YAML (snippet)
script: !include scripts.yaml
sensor: !include sensors.yaml
binary_sensor: !include binary_sensors.yaml
template:
  - binary_sensor: !include template_binary_sensors.yaml
  - sensor: !include template_sensors.yaml
  - trigger: !include template_trigger_based_sensors.yaml
TEMPLATE TRIGGER BASED SENSORS.YAML
# Trigger-Based sensors ###
- triggers:
    trigger: state
    entity_id: timer.five_mins
    - name: test3_five_min_timer
      state: "{{ states('timer.five_mins') }}"
- triggers:
    trigger: state
    entity_id: sensor.average_temperature
    - name: Outside Temperature last known value
      state: "{{ states('sensor.average_temperature') }}"
I’m not a YAML expert, but I have never seen anything in the HA docs that indicate you can list “includes” like that. What I have seen is using labelled keys:
template binary_sensor: !include template_binary_sensors.yaml
template sensor: !include template_sensors.yaml
template trigger: !include template_trigger_based_sensors.yaml
Didgeridrew,
Thanks for your reply I’ve tried your suggestion but it did not work either. Just FYI, the snippet below works for state-based template binary_sensor and sensor, but I cannot get the trigger-based template to work.
I have it this way
in templates.yaml
# Triggered  Sensors
- trigger:
Hello Francis,
The binary_sensor and sensor works, but still not luck on the trigger:
You can’t list trigger that way. You have to include a whole folder at the root level to include files with trigger.
I have this in my configuration.yaml file:
Then in my templates.yaml file I have this:
  ### Trigger based sensor to store calendar events ###
- trigger:
  - platform: event
    event_type: calendar_poll
    - name: "Calendar Events"
      unique_id: calendar_events
      state: "{{ trigger.event.data.calendar_response.events | count() }}"
      attributes:
        calendar_response: "{{ trigger.event.data.calendar_response }}"
      icon: mdi:calendar
To elaborate on my last comment. What you are doing is this:
template:
- trigger:
  - trigger:
which is not valid template yaml.
Because triggers are paired with template entities, the only proper way to add separate trigger based entities inside separate files would be:
template: !include_dir_merge_list template
Then make a template folder in configuration.yaml.
Then inside the template folder, you can have any number of listed template entities. Those template entities can be trigger based or not, but you’d need to alter your current sensor and binary_sensor file to include those slugs.
