Adding Tuya car door opener, no controls available
Hi.
I am trying to integrate a tuya door opener. TS0601
by _TZE204_nklqjk62
I have read and tried to do about a dozen or so forum posts about how to do that, none seem to work.
I can see the device info, diagnostic and logs
A lot of forum posts seem to be mentioning the need for quirks, each with a different way to go about it. I see in the device info “Quirk: zhaquirks.tuya.ts0601_garage.TuyaGarageSwitchTO”
What am I doing wrong?
The quirk is applied, but the entities weren’t created. Two things I would try, we used to have a bug where entities wouldn’t show unless you rebooted Home Assistant, I would try that first. If that fails, remove and rejoin the device.
I have tried both but neither worked
Turn debug logging on and then reload ZHA, any errors?
