Adding Tuya devices to Tuya app via 3rd party (nortek) usb dongle
New to HA, first post. I’ve searched the forum, and although I can find several posts about adding zigbee devices to HA via the nortek dongle, I cannot find a resolution to my issue.
My question: Is it possible to add Tuya compatible devices to the Tuya app using the Nortek USB dongle without the stock Zigbee hub?
Running Core HA on PI 3 using the Nortek HUSBZB-1. Purchased my first Moes touch light switch from Amazon (ZTS-US). Pairing the switch to the Nortek went without issue and I’m able to use the basic on/off command. However, I would like to be able to use additional features of the switch, most importantly being able to control the backlight to the switch which is advertised as an option via the Tuya App. Downloaded the Tuya App and tried to add the switch to the app, however Tuya first wants to pair with the original zigbee hub which I am not using and therefore I cannot add the switch to Tuya. From what I’ve researched, it doesn’t appear that the Nortek dongle has a “pairing mode” which seems to be what the Tuya app is looking for. Am I missing something?
You really need a Tuya hub to pair to the Tuya app.
Thanks for your reply Francis…looks like I’ll be purchasing the Tuya hub!
