I’ve added an smart-life/tuya irrigation controller to my network.
The device is not recognized automatically by the home-assistant tuya integration.
How can I add the device to the Tuya integration
Hi, did you come right with this?
I am considering buying the same device… the other option of course is to DIY it completely and use for example a Shelly 1 per irrigation valve since the shelly 1 has dry contacts and so can control the 24Vac circuit for the solenoid even though it’s running on 230 V or whatever as the case might be… and then use automations in HA for timer and weather based activation along with manual controls… I know there’s also Sonoff 4ch pro3 … which could work … but this doesnt have DIY / local lan mode and so my understanding is adding to HA is not that simple as with Shelly… and i have 6 zones so would need 2 anyways…
Any update on this, I’m thinking re the same.
Anyone linked it with a mi flora?
