Hi folks, I bought 3 tuya bulbs, I want msnage them from HA but without success, can someone guide me to make works my tuya bulbs in HA, I already did some research here I find some topics that talk only about only the issues that were facing without given a clear plan , I didn’t find a topic that explain the whole integration from the beginning to the end.
I tried to start implementing a basic plan that I found here in docs ,I added those below lines in config:
tuya
username: [email protected]
password: mypass
country_code: ‘1’
platform: ‘tuya’
But it generated this error:
Error doing job: Task exception was never retrieved
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 408, in _async_add_entity await entity.async_update_ha_state() File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 275, in async_update_ha_state self._async_write_ha_state() File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 316, in _async_write_ha_state attr.update(self.state_attributes or {}) File “/usr/src/homeassistant/homeassistant/components/light/init.py”, line 477, in state_attributes data[ATTR_BRIGHTNESS] = self.brightness File “/usr/src/homeassistant/homeassistant/components/tuya/light.py”, line 43, in brightness if self.tuya.brightness() is None: File “/usr/local/lib/python3.7/site-packages/tuyaha/devices/light.py”, line 16, in brightness brightness = int(self.data.get(‘color’).get(‘brightness’) * 255 / 100) AttributeError: ‘NoneType’ object has no attribute ‘get’
If someone had already a solution to this issue please shared it with me . Thanks in advance.
