Hi there,
I am still new at HA and have started building my configuration. Please allow me some stupid questions on yaml and configuration, this helps my learning
I am using the Climate Group integration via HACS (GitHub - bjrnptrsn/climate_group: Home Assistant Climate Group) I could configure and starting to build one working group entity with adding the following
climate:
- platform: climate_group
temperature_unit: C # optional: 'C' or 'F' [default: 'C']
unique_id: 'fd9090f2-fd00-4280-a4c6-338e5f8ef81b' # optional: any UUID [default: None]
entities:
- climate.kuche_thermostat_1_climate
- climate.kuche_thermostat_2_climate
Now I want to build another group of 2 thermostats for another room but I do not get this to work. Could you please advise the code I would need to add. This would be the
Do I need to start with “climate: and platform: climate group” again?
unique_id: '2a205ac7-e04a-4615-846b-8072c309d017' # optional: any UUID [default: None]
entities:
- climate.thermostat_lounge_climate
- climate.lounge_thermostat_kleiner_heizkorper_climate
I tried to add this last code under the first group but don’t get it to work. In file editor this error appears and in the entity overview I find this error. What do I wrong?
Sorry again for the nooby questions.
Edit: Error from File Editor: duplicated mapping key (31:5)
28 | entities:
29 | - climate.kuche_thermostat_1_cl ...
30 | - climate.kuche_thermostat_2_cl ...
31 | name: 'Lounge-Thermostate-All'
32 | temperature_unit: C # optiona ...
33 | unique_id: '2a205ac7-e04a-4615- ...
Error from Entity: This entity is no longer being provided by the climate_group integration. If the entity is no longer in use, delete it in settings.
