Hi!
I’m trying to make an home button, which includes turning on specific lights and heating my house by my thermostats from Netatmo. However, the lights should only turn on after sunset. I think the only option for this to work is to make two scenes: one for the thermostats and one for the lights, and then combine these into one scene.
And here is my problem: it won’t work! When I activate the scene, nothing happens, although the two scenes works individually. Has anyone experienced the same problem?
The scene config is this:
- id: '1587665066579'
entities:
scene.lys_ved_ankomst_2:
entity_id:
- light.entre
- light.kokken
friendly_name: 'Lys ved ankomst 2 '
state: scening
scene.termostater_ved_ankomst:
entity_id:
- climate.netatmo_gang
- climate.netatmo_kokken
- climate.netatmo_kontor
- climate.netatmo_sovevaerelse
- climate.netatmo_stue
friendly_name: Termostater ved ankomst
state: scening
- id: '1587316917480'
entities:
climate.netatmo_gang:
battery_level: 90
current_temperature: 19.5
friendly_name: Netatmo Gang
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_mode: Schedule
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
supported_features: 17
target_temp_step: 0.5
temperature: 16
climate.netatmo_kokken:
battery_level: 91
current_temperature: 20
friendly_name: Netatmo Køkken
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 16
climate.netatmo_kontor:
battery_level: 89
friendly_name: Netatmo Kontor
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 16
climate.netatmo_sovevaerelse:
battery_level: 91
friendly_name: Netatmo Soveværelse
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 16
climate.netatmo_stue:
battery_level: 90
current_temperature: 21
friendly_name: Netatmo Stue
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 20
- id: '1587664880677'
entities:
light.entre:
brightness: 254
friendly_name: Entré
state: 'on'
supported_features: 41
light.kokken:
brightness: 254
effect: none
effect_list:
- colorloop
- random
friendly_name: Køkken
hs_color:
- 255.059
- 100
max_mireds: 500
min_mireds: 153
rgb_color:
- 64
- 0
- 255
state: 'on'
supported_features: 63
xy_color:
- 0.158
- 0.05
tom_l
April 24, 2020, 9:09am
2
Without seeing any of your scene or button configuration it is hard to say anything useful.
tom_l
April 24, 2020, 9:16am
4
Please format them correctly.
I think it is easier to read through pastebin
https://pastebin.com/0TeQyN76
tom_l
April 24, 2020, 9:17am
6
Ok, i see. Hope this is better
entities:
entity_id:
- light.entre
- light.kokken
state: scening
entity_id:
state: scening
entities:
battery_level: 90
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 16
battery_level: 91
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 16
battery_level: 89
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 16
battery_level: 91
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 16
battery_level: 90
hvac_action: idle
hvac_modes:
- auto
- heat
max_temp: 35
min_temp: 7
preset_modes:
- away
- boost
- Frost Guard
- Schedule
state: auto
temperature: 20
entities:
light.entre:
brightness: 254
state: 'on'
light.kokken:
brightness: 254
effect: none
effect_list:
- colorloop
- random
hs_color:
- 255.059
- 100
max_mireds: 500
min_mireds: 153
rgb_color:
- 64
- 0
- 255
state: 'on'
xy_color:
- 0.158
- 0.05
tom_l
April 24, 2020, 9:45am
8
I don’t know if you can use scenes as entities in scenes. You can use them in scripts:
script:
- home_button
sequence:
- service: scene_turn_on
entity_id: scene.termostater_ved_ankomst
- condition: state
entity_id: sun.sun
state: below_horizon
entity_id: scene.lys_ved_ankomst_2
Call the script from your button tap action as a service like this:
type: button
tap_action:
action: call-service
service: script.home_button
then this problem pops up
tom_l
April 24, 2020, 10:07am
10
Apologies I missed a colon after the script name. Should be:
- home_button:
If I wasn’t this new on home assistant, I could’ve probably seen it myself.
however, I don’t understand this problem when checking the config:
tom_l
April 24, 2020, 10:22am
12
Try this:
script:
home_button:
sequence:
- condition: state
entity_id: sun.sun
Note the lack of “-” in front of the script name. It’s been a while since I wrote a script. I forgot they were dictionaries not lists.
Now it looks like this:
script:
home_button:
sequence:
- condition: state
entity_id: sun.sun
tom_l
April 24, 2020, 10:29am
14
Of ffs. I’m not having a good day.
script:
home_button:
sequence:
- service: scene.turn_on
- condition: state
entity_id: sun.sun
Finally it works! I have been using too many hours to fix this!!
Thank you!
tom_l
April 24, 2020, 10:40am
16
No worries. Apologies for the appalling amount of errors in the original script.
Hopefully you learned a bit about what the error messages were trying to say though.
