Anyone know if there is a possibility to add a unit of measurement to an attribute show on entities cards in lovelace?
I have an Entities card, which shows different utility meters, and I would like to show last_period attribute value from utility meter on it. It’s showing the correct value, but without unit.
I’ve tried: unit: , unit_of_measurement: but none of them works.
Alternativly, maybe attribute last_period from utility meter can be customized to add units there, but I cannot find any documentation how to customize an attribute. It looks like that customization corresponds to entity value only and not attributes.
There is how it looks like:
There is a part of code for this:
- type: entities
entities:
- entity: sensor.pv_money_saved_today
icon: mdi:currency-eur-off
secondary_info: none
- entity: sensor.grid_energy_cost_today
type: attribute
attribute: last_period
name: PV Money saved - Yesterday
unit: "DKK" ### not working###
eggman
(bertie basset)
October 16, 2022, 10:58am
2
Ars4l4n
(Arsalan)
July 26, 2024, 12:05pm
3
That does nothing for me, even upon clicking “Save”.
beecho01
(James Beeching)
July 26, 2024, 12:26pm
4
I think here you need to use an attribute to show a suffix as documented here: Entities card - Home Assistant
type: entities
entities:
- entitiy: sensor.wie_lang_zuletzt_geschalfen
attribute: attribute_name_here
icon: mdi:sleep
suffix: h
Hope that helps!
Ars4l4n
(Arsalan)
July 26, 2024, 12:48pm
6
Am I supposed to enter the name of the actual unit attribute?
Either way, it doesn’t work.
beecho01
(James Beeching)
July 26, 2024, 12:55pm
7
As the unit is not shown as an attribute you may need to use something like ‘lovelace-template-entity-row’ from the HACS store. Information on how to install is here: GitHub - thomasloven/lovelace-template-entity-row: 🔹 Display whatever you want in an entities card row.
Then you could try something like:
entities:
- type: 'custom:template-entity-row'
entity: sensor.wie_lang_zuletzt_geschalfen
state: |
return entity.state + ' h';
Because you have not specified a proper 'type: attribute" here
Ars4l4n
(Arsalan)
July 26, 2024, 1:37pm
9
Like this?
That just throws an error.
Because you specified an attribute - but forgot to specify an entity.
Ars4l4n
(Arsalan)
July 26, 2024, 4:24pm
11
I’m confused. Does - entitiy: sensor.wie_lang_zuletzt_geschalfen not count as specifying an entity?
@beecho01
With the custom component it worked like this:
type: entities
entities:
entity: sensor.wie_lang_zuletzt_geschlafen
state: "{{states('sensor.wie_lang_zuletzt_geschlafen')}} h"
Don’t know how to do the conversion though, as the time is shown as 6,81 h rather than 6:48 h.
It does count - but you did not specify an entity for THAT particular row.
Check this:
Every “-” describes a “row”:
1st row - shows an entity’s state
2nd row - shows an entity’s attribute
