Adding unknown bluetooth devices
I’m installing Home Assistant in my camper and looking for a solution to integrate the various bluetooth devices that are in/on it already. I’ve dug around in the standard integrations and in HACS and there only seems to be support for “known” devices. I’d like to be able to pick up all devices, and have them added to HA so that I can scrape the various services offered.
Currently, I’m looking to integrate the following:
  • Hughes Power Watchdog (surge suppressor, power monitor)
  • TyMate Tire Pressure/Temperature Monitors
  • LevelMatePro camper level sensor
I’ve used BLE sniffers and found that for everything above the data is transmitted is somewhat easy to extract… Has anyone found an integration of any sort that can get abstract data in to HA from random BLE devices? If not, what in your opinion would be the next best approach?
TIA,
Terry
if you had already found out service IDs and data formats, you can add support to this custom integration (https://github.com/custom-components/ble_monitor) and you can start fetching data.
Adding a new device is fairly straightforward: Documentation on documentation - Passive BLE Monitor integration
Thanks, I had considered that as a possible route. I’ll look into it further.
Terry
The Hughes Power Watchdog is on a lot of smart RV people’s to-do lists, including mine. I’ve played around with a BLE sniffer app a little. The issue we run into is the Hughes only puts out a generic BLE advertisement. You don’t get the data until you connect. Apparently the RV Whisper guy found a way around this, but he’s not willing to share how. Have you found a way around this? I’d LOVE to be able to get my power consumption into HA from my Hughes.
Not sure if this brand is compatible, but Theengs and OpenMQTTGateway already decode generic BLE TPMS.
You don’t see any change of the advertisement depending on the power consumption ?
From what we can tell, it’s encrypted. Only one characteristic is subscribable and it updates 8-10 values every second, but the values themselves are meaningless. We’ve tried converting to various different formats but nothing works. It’s been suggested that someone attempt to flash Tasmota to the internal ESP32 to gain access to the encryption key needed. The good news is it’s possible to utilize the information (otherwise RVWhisper wouldn’t be able to use it). We just have to figure out how he gained access. Worst case scenario, we pay the $200 for his “gateway” (which is probably just a $12 ESP32) and look at the source code. But nobody wants to pay for something when we can probably do it ourselves.
I know very little about BLE but I’ve been trying to figure out how to access the power watchdog myself. You can run the iOS app on an M1 Mac and use Xcode’s PacketLogger to see what’s happening but I’ve still to figure it out fully. Any progress I find I’ll happily share! I’m glad I’m not alone haha
Oh my goodness. Whilst I was sitting at our campfire outside our RV, I was able to reverse engineer the android app and figure out exactly how to pull the data out of the subscribable characteristic. I’ve written a python script using the bleak package which works on both Windows and macOS.
I’m not entirely sure what line means- it’s either 2 or 1- but the rest of the values are just 4 byte integers that need to be divided by 10,000. This was as much as there was when I decompiled the apk. It’s so inefficient and confusing but hey, the data is correct!
{'volts': 120.2846, 'amps': 15.32, 'watts': 1738.4, 'energy': 702.37, 'line': 2}
Looking at it, I guess we only need the first packet starting with 01 03 20. I’m gonna try to turn this into something I can use with home assistant and publish it on github, though I’m still trying to get a raspberry pi for my camper but I’m working on it in the meantime.
There’s an ascii diagram in the code but here it is anyway:
# 0 => 01 03 20 00 12 5b a4 00 01 43 07 00 93 c8 08 00 6a cd 68 00
#      \______/ \_________/ \_________/ \_________/ \_________/
#       header     volts       amps        watts       energy
# 1 => 00 03 d0 00 53 d7 01 ff df 10 00 00 00 17 6d c7 1c 00 00 00
#                                                         \______/
#                                                           line
Just make sure to run pip install bleak first:
import asyncio
import platform
from bleak import BleakScanner, BleakError, BleakClient
address = (
    "mac address here"
    if platform.system() != "Darwin" else
    "uuid here for macos"
async def main():
    # devices = await BleakScanner.discover()
    # for device in devices:
    #     print(device)
    device = await BleakScanner.find_device_by_address(address, timeout=5)
    if not device:
        raise BleakError("Device not found")
    async with BleakClient(device) as client:
        if not client.is_connected:
            await client.connect()
        first_chunk = None
        def on_data(sender, chunk):
            chunk = bytes(chunk)
            global first_chunk
            if chunk[0] == 1 and chunk[1] == 3 and chunk[2] == 32:
                first_chunk = chunk
            else:
                # we got the second chunk which includes the rest of the data
                buffer = first_chunk + chunk
                first_chunk = None
                #                                                         \______/
                #                                                           line
                volts = int.from_bytes(buffer[3:7], "big") / 10000
                amps = int.from_bytes(buffer[7:11], "big") / 10000
                watts = int.from_bytes(buffer[11:15], "big") / 10000
                energy = int.from_bytes(buffer[15:19], "big") / 10000
                line = None
                if buffer[37] == 0 and buffer[38] == 0 and buffer[39] == 0:
                    line = 2
                elif buffer[37] == 1 and buffer[38] == 1 and buffer[39] == 1:
                    line = 1
                print({
                    "volts": volts,
                    "amps": amps,
                    "watts": watts,
                    "energy": energy,
                    "line": line,
        # for service in client.services:
        #     print(service)
        #     for char in service.characteristics:
        #         print(char)
        await client.start_notify("0000ffe2-0000-1000-8000-00805f9b34fb", on_data)
        while True:
            await asyncio.sleep(1)
asyncio.run(main())
Woo! Great work! Line (if it always says 2) could be the number of lines (2 for a 50amp service) or maybe the amperage of the lines combined? And I assume “energy” is the current wattage being pulled, while “watts” is the cumulative count. Now we just need to figure out how to get an ESP32 to capture that data and have HA decode it. One sensor on ESPHome to capture that characteristic, and a script to convert it? Feel free to DM me to collab, we’re full timers with HA running on a RPi4. I’d like to use an ESP32 instead of the built-in Bluetooth since I run a SSD attached to the RPi, which makes the built-in Bluetooth pretty useless. I already have an ESP32 in the pass-thru thats partially wired up to my black/grey tanks for my tank level project. So it can handle both projects.
Energy is cumulative kWh and watts is wattage. I just lifted the same variable names they used. I’d love to collaborate! I’ve never used ESPHome before but it’s definitely possible to write this onto a microcontroller, I’d prefer to do it that way too. I’ll look into it later today or alternatively we could contact each other and figure it out together. I’m on Discord
Well, we finally did it. The Hughes Power Watchdog is FINALLY integrated into HomeAssistant! Special thanks to all those who helped along the way. It’s still a very new integration, so if you experience any issues, please submit and issue on the github repo. Enjoy!
Thank you so much!
Now I’ll need to work on tire pressure and level.
Is the ESP device required, or can I use the BLE Bluetooth on my NUC?
Did you ever make any progress on this?
LevelMate Pro is on my list. The big one is seeing if I can somehow sniff out and integrate my LCI OneControl system. I haven’t the foggiest clue what I’m doing but, I dunno, gotta learn somewhere right? That would give me lights, pumps, tank monitors… everything!
I can’t help with the LevelMate Pro, but, depending on the control board your OneControl uses, you actually can integrate it in HA. My friend Bob made a github repo for the work he did, but he no longer has a rig that supports it. Take a look and see if it’s helpful in your journey.
If you’re looking for assistance, we do have a Facebook group and a Discord group that are fairly active.
Facebook: Redirecting...
Discord: DIY Smart RV
Yeah; the key difference is that Bob’s system includes the “Connect Anywhere” add-on. That includes a component called a “Cloud Bridge” which is essentially a cheap router and CANBUS interface with the OneControl control unit. The purpose of it is so that you can use the LCI OneControl app anywhere over the internet instead of having to use Bluetooth. I think the whole package even includes a cellular modem to make your LCI OneControl system work ‘from anywhere’ if you pay some insane amount of money for data through them. Which of course is doubly silly since I already have an internet connection in the RV.
I don’t have that add-on. Looks like Bob has (had) Grand Design RV’s and those are a little higher end and probably just include those options; I didn’t elect to purchase that option when I bought my RV. Purchasing that little extra unit even used on eBay is $500+; obnoxiously expensive for a crummy router. I found some other projects where people were trying to intercept or communicate with the CANBUS system directly but none that managed to succeed in doing so.
I’ll keep tinkering but; we’ll see! LevelMate Pro is far less interesting, but I had hoped someone had maybe got it working just because it would be neat. One of my goals with Home Assistant has been replace the 11 different apps that had some sort of function related to my RV. (I’m even counting E-Mail as one of those apps because I often have to check my E-Mail to see what site number I booked! I’ve since written a little python script that pulls data from Google Calendar and gives me a dashboard with what site number and location I have booked next.)
Right now; I’m down to three! Home Assistant, LCI OneControl, and LevelMate Pro. Every other function, monitoring, device, whatever is all controlled through Home Assistant or the data is available on a Home Assistant dashboard.
Thanks so much for the discord invite! I’ll check it out!
Did you ever get anywhere with the LevelMate Pro?
I’d love to have this in my HA.
Or any luck with LCI OneControl?
Do you have the cloud gateway from Lci?
Negative - just came across the LCI OneControl panel in my camper today and have been trying to find out how to integrate - appears to be only bluetooth from what I can tell - in a 2023 Forest River LaCrosse.
