Adding weather Solar Lux to Solar Production in Energy Panel
I am wondering If there is a way to incorporate my Ecowitt weather stations Solar Lux sensor results to the Solar Production graph in the Energy Panel? As I would like to see the comparison between the sun brightness vs solar production throughout the day. Or would it just be easier to create a new graph on the dashboard?
Thanks for any help you can provide.
The energy dashboad only allows energy sensors to be added. if you create a template to calculate the kWh, then yes you can add this, but it will mess up your data.
Better use something like the Statistics graph Card or Apex Chart to get what you want. You can also use the energy cards to make a custom energy dashboard.
