I’m trying to add a separate dashboard which has tabs which display pages like PiHole, WebMin, and my router config page. It does not need to be visible outside the local network, and in fact I very much do NOT want it visible outside my local network.
I added a dashboard for “Server”, and have tried adding Webpage (iframe) cards. It will display certain pages, but not others.
For instance, if I link to the IP of my PiHole server (same as hass server), then it will display the page saying “are you looking for the pihole dashboard?”, but if I try to display the pihole dashbaord itself, it says it cannot connect. Note that I am viewing Home Assistant locally and over http rather than https.
The same happens for webmin and other local pages as well. I assume it’s because these pages are PHP and ASP, and that Home Assistant’s iframes will not run these, but prefer static pages.
