Adding Yaml conf in configuration.yaml
Hallo ,
I’m having an issue to include extra yaml files into my configuration.yaml. I tried differed ways , looked all over youtube and even started a new Home assistant server to test from scratch. Probably I’m doing something wrong
I’m using the Following code in my configuration ( I added the cameras.yaml )
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
camera: !include cameras.yaml
#### alamrs #####
alarm_control_panel:
  - platform: manual
and the following code in the cameras.yaml
camera:
  - platform: generic
    still_image_url: "http://xxx.xxx.xxx.xxx/ISAPI/Streaming/Channels/101/picture"
    stream_source: "rtsp://user:[email protected]:554/Streaming/Channels/102"
    verify_ssl: false
    username: "xxxxxx"
    password: "xxxxxxxxx"
    authentication: digest
When I use the same code directly in the configuration.yaml everything works fine. What is I’m doing wrong :worried:
It’s still work in progress , but I already created the following dashboard.
because it started to get crowded in the Configuration file I would like to split some things up as I go further .
Thanks a lot
Remove or comment out this from your cameras.yaml
Yes , it works ,
It was that easy . :man_facepalming:, I overlooked it somewhere
Thank you !!
I keep getting the following error code and can’t figure out why its not working. It was working before without issue but I was recently adding new code for alexa switches then started getting errors that point me to the lines for my camera. Can anyone tell whats going on. I checked all the spacing?
Configuration errors
Error loading /config/configuration.yaml: while parsing a block collection
** in “/config/configuration.yaml”, line 20, column 3**
expected , but found ‘?’
** in “/config/configuration.yaml”, line 36, column 3**
amcrest:
  • host: 192.168.xx.xxx
    username: admin
    password:
    binary_sensors:
    • motion_detected
    • crossline_detected
    • online
  • host: 192.168.xx.xxxx
    username: admin
    password:
    binary_sensors:
    • motion_detected
    • online
      sensors:
    • sdcard
Add thrid camera
    username: admin
    password:
    binary_sensors:
    • motion_detected
    • online
      resolution: low
      stream_source: snapshot
      sensors:
    • ptz_preset
Add forth camera
    username: admin
    password:
    binary_sensors:
    • motion_detected
    • online
Add fifth camera
    username: admin
    password:
    binary_sensors:
    • motion_detected
    • online
Add sixth camera
    username: admin
    password:
    binary_sensors:
    • motion_detected
    • online
Add sevnth camera
    username: admin
    password:
    binary_sensors:
    • motion_detected
Your yaml is invalid, or you did post it wrong (not properly formatted)
I think I posted it wrong… I"ll correct and repost
amcrest:
  - host: 192.168.xx.xx
    username: admin
    password: xx.xx
    binary_sensors:
      - motion_detected
      - crossline_detected
      - online
    username: admin
    password: xx.xx
    binary_sensors:
      - motion_detected
      - online
  sensors:
      - sdcard
  # Add thrid camera
    username: admin
    password: xx
    binary_sensors:
      - motion_detected
      - online
    resolution: low
    sensors:
      - ptz_preset
  # Add forth camera
  - host: 192.168.xx.xxx
    username: admin
    password: xx
    binary_sensors:
      - motion_detected
      - online
  # Add fifth camera
    username: admin
    password:
    binary_sensors:
      - motion_detected
      - online
  #Add sixth camera
    username: admin
    password:
    binary_sensors:
      - motion_detected
      - online
#seventh camera
    username: admin
    password: xxx
    binary_sensors:
      - motion_detected
      - online
