Hi folks
I’ve had a bunch of Aeotec Nano Switches and Dimmers installed recently by a professional electrician.
Because I didn’t have HA setup at that stage, I got the electrician to walk around and pair the modules to the Aeotec Z-Wave stick using the stick and the physical button on the stick.
Now that HASS is up and running I’ve read in the HASS documentation that devices should not be added using the controller but only using HASS/Add Node.
My setup seems to be working ok - all nodes are detected and I only have an issue with the dimmers which may be unrelated. So my question is whether I need to remove the Aeotec modules from HASS and reset/re-add them using the HASS method?
Re-adding would be a major pain and cost as I’d need to get the electrician to remove all switches again and reinstall. Is there any way to confirm if the current pairing method (using physical controller) worked ok?
Any advice appreciated, thanks!
