I’m starting to play around with my new RPi (Raspbian Jessie) on which I installed Home Assistant with no problem.
For now, I only have a ZWave controller (a ZME UZB1) an a ZWave Plug (Everspring AD147). So I tried installing my ZWave controller on Home Assistant and I managed to configure it but now I have two switches that appeared on the web interface. I don’t know what they are because I did not plug any ZWave device yet.
Also, I don’t see how I can set the controller to inclusion mode to add my new ZWave plug.
A very late reply, but i would recommend OpenZWave Control Panel. If you can get it running (I had some issues with it on Raspian Jessie at first) it’s a good tool.
But I also had issues with missing package (libgnutls28). I was able to fix that by running this line before following the guide: sudo apt-get update && sudo apt-get upgrade -y && sudo apt-get dist-upgrade -y
This will take a good while.
