Mutt
(Muttley)
January 27, 2020, 1:59am
21
My network is 38 nodes only 4 of them battery.
It is common practice to avoid secure
Why would you want secure.?
Do you imagine there is a guy sitting in a van at the bottom of your garden (z wave range issues) listening in to your network just so he can clone your hub just so he can turn your lights off in the toilet?
Who cares ? It’s just not worth the overhead.
Locks are a different matter, my suggestion is : - don’t buy them, use a key
@finity you are a z wave man, - your opinion ?
(feel free to disagree, I won’t be offended (just coz yore wrong ! ))
No locks here, but lots of battery powered door, window, pir sensors for alarm purposes. My slowest node is a toolshed door sensor, 100’ away in the backyard by itself. That one does take ~1sec to return, but good enough for the alarm automations. My lights, switches, etc all respond ~20-40msec added securely, which is plenty fast.
Mutt
(Muttley)
January 27, 2020, 2:04am
23
Battery devices don’t form part of the backbone (they don’t contribute to your network)
Understood… I was editing my post as your post went up lol.
Mutt
(Muttley)
January 27, 2020, 2:12am
25
Can you explain to me your perceived benefits of adding them securely ?
(but read the z wave spec documents (not HA) about message blocks etc.)
You’re making me do some reading?!! I should study the zwave spec at some point, I do appreciate the value of knowledge. However I concede the only benefit I may get from adding nodes securely is a placebo effect.
ITLogic
(Chris)
January 27, 2020, 2:37am
27
No my looks completely different. My does not have anywhere that I can add. Under Z-Wave Node Management, there only one drop down that say node but will not let you click on it. I get restart the server.
finity
January 27, 2020, 3:39am
28
I add everything securely if the device supports it. I figure there is a reason for it and it’s usually better to err on the side of more secure rather than less. But it may also be as truglodite says above and only a placebo effect.
I have 24 nodes (half battery powered) and I don’t really notice any latency in my system. I guess it’s possible that I would have less latency (less than almost none…? ) without using security but I don’t see any issues the way it is now.
as far as the zwave integration I was under the impression that the zwave config in configuration.yaml was unecessary since you can do it all thru the UI. The only time the config in the configuration.yaml is needed is to override any config done thru the UI.
But I don’t use hassio and I do use the config in configuration.yaml so I’m no expert…
but to the OP you shouldn’t have to click on the drop down for any node to be able to see the “add node” or “add node secure” buttons. They aren’t associated with a node. They are associated with the system as a whole.
I’m kind of lost in where you are right now. I’m not sure if you configured your zwave thru the UI or in yaml.
if it’s in yaml I think I would delete that and try to add it thru the UI (restarting in between deleting & re-adding of course).
but you need to know the z stick path. As truglodite said go to the hassio hardware section and find the path there and enter it into the UI fields. As the UI says you can leave the network key blank since it will auto-generate one for you.
click “submit” and wait 15 -20 minutes for zwave to install. then see where you end up.
myle
(StePhan McKillen (Other kiwi Here))
January 27, 2020, 10:42am
29
nice theme which one is that ??
Mutt
(Muttley)
January 27, 2020, 11:22am
30
I think it’s one of juantec’s called grey - orange.
There’s an issue with the original that you get white text on a white background in unused entities.
I ‘think’ Teras helped me out in finding the missing element.
I can post the whole ‘modified’ file if you want it (it didn’t cost me anything )
Mutt
(Muttley)
January 27, 2020, 11:45am
31
I find that really funny !
I’ll put it in American terms for you but it’s like saying : -
I live in Florida (other hot States are available) I have a trunk in my car, I fill it with snow shoes, a couple of snow shovels (one as a spare), iron rations, a couple of bags of salt and a couple of 50 lb bags of sand - I get really shitty gas mileage but it gives me a sense of security
finity
January 27, 2020, 12:06pm
32
I’ll forgive the grossly erroneous analogy. You are British, after all…
But actually it’s like saying “I live in Florida but I make a bunch of trips to the frozen north every year so I keep a bunch of “frozen north stuff” in my trunk. It doesn’t seem to cause any issues with gas mileage or any other detrimental effects that I’ve been able to notice so i feel it’s better to have it and not need it than to need it and not have it.”
…Yeah, I think that’s more like what I was saying…
Mutt
(Muttley)
January 27, 2020, 12:11pm
33
Sorry Chris, we appear to have hijacked your thread with ‘mutiple’ unrelated discussions.
But it’s supposed to be a community so I figure we go where the conversation takes us.
Can you post an image of what you see under - configuration - z wave ?
Just so we are all on the same page.?
Mutt
(Muttley)
January 27, 2020, 2:15pm
34
Take the theme you want from my themes.yaml in the file below (or just the entire) : -
Credit goes to JuanTec and Taras
Dark - Blue:
### Main Interface Colors ###
primary-color: "#2F7EFD"
light-primary-color: "#6FA6FE"
primary-background-color: "#1F1F28"
secondary-background-color: var(--primary-background-color)
divider-color: "#2F2F3D"
### Text ###
primary-text-color: "#FFFFFF"
secondary-text-color: "#6FA6FE"
text-primary-color: "#FFFFFF"
disabled-text-color: "#4E4E66"
### Sidebar Menu ###
sidebar-icon-color: "#B6B6C1"
sidebar-text-color: "#F1F1F1"
sidebar-selected-background-color: var(--primary-background-color)
sidebar-selected-icon-color: "#6FA6FE"
sidebar-selected-text-color: var(--sidebar-selected-icon-color)
### States and Badges ###
state-icon-color: "#2F7EFD"
state-icon-active-color: "#FBCD41"
state-icon-unavailable-color: var(--disabled-text-color)
### Sliders ###
paper-slider-knob-color: "#2F7EFD"
paper-slider-knob-start-color: var(--paper-slider-knob-color)
paper-slider-pin-color: var(--paper-slider-knob-color)
paper-slider-active-color: var(--paper-slider-knob-color)
paper-slider-secondary-color: var(--light-primary-color)
### Labels ###
label-badge-background-color: "#23232E"
label-badge-text-color: "#F1F1F1"
label-badge-red: "#6FA6FE"
### Cards ###
paper-card-background-color: "#23232E"
paper-listbox-background-color: var(--primary-background-color)
card-background-color: "var(--paper-card-background-color)"
### Toggles ###
paper-toggle-button-checked-button-color: "#2F7EFD"
paper-toggle-button-checked-bar-color: "#6FA6FE"
paper-toggle-button-unchecked-button-color: var(--paper-toggle-button-checked-button-color)
paper-toggle-button-unchecked-bar-color: "#3E4756"
### Table row ###
table-row-background-color: var(--primary-background-color)
table-row-alternative-background-color: var(--secondary-background-color)
Dark - Blue/Purple:
primary-color: "#007AFF"
light-primary-color: "#4DA3FF"
primary-background-color: "#141A32"
divider-color: "#3B4C8B"
### Text ###
secondary-text-color: "#4DA3FF"
disabled-text-color: "#4F5F78"
sidebar-icon-color: "#4F6B95"
sidebar-text-color: "#CBD5E4"
sidebar-selected-icon-color: "#4DA3FF"
state-icon-color: "#007AFF"
### Sliders ###
paper-slider-knob-color: "#007AFF"
### Labels ###
label-badge-background-color: "#1E2747"
label-badge-text-color: "#FFFFFF"
label-badge-red: "#3B4C8B"
### Cards ###
paper-card-background-color: "#1E2747"
### Toggles ###
paper-toggle-button-checked-button-color: "#FCFCFC"
paper-toggle-button-checked-bar-color: "#4DA3FF"
paper-toggle-button-unchecked-bar-color: "#303F79"
### Table row ###
Dark - Cyan:
primary-color: "#00E4D7"
light-primary-color: "#71FFF7"
divider-color: "#2C2C39"
### Text ###
primary-text-color: "#F7F8FA"
secondary-text-color: "#00E2D8"
disabled-text-color: "#5B7283"
sidebar-icon-color: "#BCC5D1"
sidebar-text-color: "#F7F8FA"
sidebar-selected-icon-color: "#00E2D8"
state-icon-color: "#00C5E3"
### Sliders ###
paper-slider-knob-color: "#00E2D8"
paper-slider-secondary-color: "#00C5E3"
### Labels ###
label-badge-background-color: "#2F2F3D"
label-badge-text-color: "#F7F8FA"
label-badge-red: "#444459"
### Cards ###
### Toggles ###
paper-toggle-button-checked-button-color: "#00E2D8"
paper-toggle-button-checked-bar-color: "#00EDE0"
paper-toggle-button-unchecked-button-color: "#A8B3C3"
paper-toggle-button-unchecked-bar-color: "#CED5DD"
### Table row ###
Dark - Green:
primary-color: "#03B14B"
light-primary-color: "#47FC92"
### Text ###
secondary-text-color: "#47FC92"
disabled-text-color: "#464653"
sidebar-selected-icon-color: "#47FC92"
state-icon-color: "#04E762"
state-icon-active-color: "#FBD150"
### Sliders ###
paper-slider-knob-color: "#04E762"
### Labels ###
label-badge-background-color: "#464653"
label-badge-red: "#343443"
### Cards ###
### Toggles ###
paper-toggle-button-checked-button-color: "#04E762"
paper-toggle-button-checked-bar-color: "#47FC92"
paper-toggle-button-unchecked-bar-color: "#343443"
### Table row ###
Dark - Orange:
primary-color: "#FF8300"
light-primary-color: "#FFA23F"
divider-color: "#353544"
### Text ###
secondary-text-color: "#FF8300"
disabled-text-color: "#595975"
sidebar-icon-color: "#7D8BA6"
sidebar-selected-icon-color: "#FFA23F"
state-icon-color: "#FF8300"
### Sliders ###
paper-slider-knob-color: "#FF8300"
### Labels ###
label-badge-background-color: "#363647"
label-badge-red: "#FFA23F"
### Cards ###
### Toggles ###
paper-toggle-button-checked-button-color: "#FF8300"
paper-toggle-button-checked-bar-color: "#FFA23F"
paper-toggle-button-unchecked-button-color: "#767679"
paper-toggle-button-unchecked-bar-color: "#444446"
### Table row ###
Dark - Pink:
primary-color: "#FF6262"
light-primary-color: "#FF8888"
primary-background-color: "#20252F"
### Text ###
secondary-text-color: "#FF8888"
disabled-text-color: "#5B5B77"
sidebar-selected-icon-color: "#FF8888"
state-icon-color: "#FF6262"
### Sliders ###
paper-slider-knob-color: "#FF6262"
### Labels ###
label-badge-background-color: "#252B36"
label-badge-red: "#6C7B9B"
### Cards ###
paper-card-background-color: "#252B36"
### Toggles ###
paper-toggle-button-checked-button-color: "#FF6262"
paper-toggle-button-checked-bar-color: "#FFA3A3"
paper-toggle-button-unchecked-button-color: "#6C7B9B"
paper-toggle-button-unchecked-bar-color: "#434E62"
### Table row ###
Dark - Purple:
primary-color: "#4C3FF9"
light-primary-color: "#6F64FA"
primary-background-color: "#262938"
divider-color: "#313549"
### Text ###
secondary-text-color: "#00ECCA"
disabled-text-color: "#616387"
sidebar-icon-color: "#4C3FF9"
sidebar-selected-icon-color: "#00ECCA"
state-icon-color: "#00ECCA"
state-icon-active-color: "#F7AA1C"
### Sliders ###
paper-slider-knob-color: "#00ECCA"
### Labels ###
label-badge-background-color: "#2E2F40"
label-badge-red: "#323346"
### Cards ###
paper-card-background-color: "#2E2F40"
### Toggles ###
paper-toggle-button-checked-button-color: "#4C3FF9"
paper-toggle-button-checked-bar-color: "#262938"
paper-toggle-button-unchecked-bar-color: "#262938"
### Table row ###
Dark - Red:
primary-color: "#EA1111"
light-primary-color: "#F35858"
primary-background-color: "#141414"
divider-color: "#2D2D2D"
### Text ###
primary-text-color: "#EAEEF1"
secondary-text-color: "#EA1111"
disabled-text-color: "#666666"
sidebar-icon-color: "#979797"
sidebar-text-color: "#EAEEF1"
sidebar-selected-icon-color: "#EA1111"
state-icon-color: "#EA1111"
### Sliders ###
paper-slider-knob-color: "#EA1111"
### Labels ###
label-badge-background-color: "#424242"
label-badge-text-color: "#EAEEF1"
label-badge-red: "#424242"
### Cards ###
paper-card-background-color: "#1A1A1A"
### Toggles ###
paper-toggle-button-checked-button-color: "#EA1111"
paper-toggle-button-checked-bar-color: "#F36060"
paper-toggle-button-unchecked-button-color: "#757575"
paper-toggle-button-unchecked-bar-color: "#424242"
### Table row ###
Dark - Yellow:
primary-color: "#FCB800"
light-primary-color: "#FFCD44"
divider-color: "#262626"
### Text ###
primary-text-color: "#EBEBEB"
secondary-text-color: "#FCB800"
text-primary-color: "#141414"
disabled-text-color: "#5D5D5D"
sidebar-icon-color: "#8E8E8E"
sidebar-text-color: "#EBEBEB"
sidebar-selected-icon-color: "#FCB800"
state-icon-color: "#FCB800"
state-icon-active-color: "#FDEAB0"
### Sliders ###
paper-slider-knob-color: "#FCB800"
### Labels ###
label-badge-background-color: "#515151"
label-badge-text-color: "#EBEBEB"
label-badge-red: "#515151"
### Cards ###
### Toggles ###
paper-toggle-button-checked-button-color: "#FCB800"
paper-toggle-button-checked-bar-color: "#FFD45D"
paper-toggle-button-unchecked-button-color: "#8E8E8E"
paper-toggle-button-unchecked-bar-color: "#515151"
### Table row ###
Grey - Green:
primary-color: "#24E081"
light-primary-color: "#6BEAAA"
primary-background-color: "#494B58"
divider-color: "#595B6B"
### Text ###
primary-text-color: "#FBFBFB"
secondary-text-color: "#24E081"
text-primary-color: "#FBFBFB"
disabled-text-color: "#7A7D90"
sidebar-icon-color: "#A2A4B2"
sidebar-text-color: "#FBFBFB"
sidebar-selected-icon-color: "#24E081"
state-icon-color: "#24E081"
### Sliders ###
paper-slider-knob-color: "#24E081"
paper-green-400: "#FBCD41"
### Labels ###
label-badge-background-color: "#9A9CAB"
label-badge-text-color: "#FBFBFB"
label-badge-red: "#555766"
### Cards ###
paper-card-background-color: "#555766"
### Toggles ###
paper-toggle-button-checked-button-color: "#24E081"
paper-toggle-button-checked-bar-color: "#6BEAAA"
paper-toggle-button-unchecked-button-color: "#A2A4B2"
paper-toggle-button-unchecked-bar-color: "#787B8F"
### Table row ###
Grey - Orange:
### Text ###
### Sliders ###
### Labels ###
### Cards ###
### Toggles ###
### Table row ###
Grey - Red:
### Text ###
### Sliders ###
### Labels ###
### Cards ###
### Toggles ###
### Table row ###
Light - Blue:
primary-background-color: "#FEFEFE"
divider-color: "#E0E2EA"
### Text ###
primary-text-color: "#4D5575"
secondary-text-color: "#2F7EFD"
disabled-text-color: "#A6B0BF"
sidebar-icon-color: "#818AAC"
sidebar-text-color: var(--sidebar-icon-color)
### Sliders ###
### Labels ###
label-badge-background-color: "#F8FAF9"
label-badge-text-color: "#4D5575"
### Cards ###
paper-card-background-color: "#FCFCFC"
### Toggles ###
paper-toggle-button-unchecked-bar-color: "#BFC6D1"
### Table row ###
Light - Cyan:
primary-background-color: "#F7F8FA"
divider-color: "#E4E8EE"
### Text ###
primary-text-color: "#6D7A8C"
disabled-text-color: "#BECAD2"
sidebar-text-color: "#6D7A8C"
### Sliders ###
### Labels ###
label-badge-background-color: "#F7F8FA"
label-badge-text-color: "#6D7A8C"
label-badge-red: "#BCC5D1"
### Cards ###
paper-card-background-color: "#FBFBFD"
### Toggles ###
### Table row ###
Light - Orange:
primary-background-color: "#F4F5F8"
divider-color: "#C1C5D5"
### Text ###
primary-text-color: "#4B4B4D"
disabled-text-color: "#A6A6BB"
sidebar-text-color: "#4B4B4D"
### Sliders ###
### Labels ###
label-badge-background-color: "#FFFFFF"
label-badge-text-color: "#4B4B4D"
### Cards ###
paper-card-background-color: "#FFFFFF"
### Toggles ###
paper-toggle-button-unchecked-bar-color: "#AAAAAD"
### Table row ###
Light - Purple:
divider-color: "#C4CCDA"
### Text ###
primary-text-color: "#2E2F40"
disabled-text-color: "#AEAFC4"
sidebar-text-color: "#2E2F40"
### Sliders ###
### Labels ###
label-badge-text-color: "#2E2F40"
label-badge-red: "#AFB0C5"
### Cards ###
### Toggles ###
### Table row ###
Navy Blue - Yellow:
primary-color: "#FEB221"
light-primary-color: "#FECA67"
primary-background-color: "#1F2635"
divider-color: "#2D374D"
### Text ###
secondary-text-color: "#FEB221"
disabled-text-color: "#4A5E84"
sidebar-icon-color: "#8192B6"
sidebar-selected-icon-color: "#FEB221"
state-icon-color: "#FEAA0A"
state-icon-active-color: "#FEF5D8"
### Sliders ###
paper-slider-knob-color: "#FEB221"
### Labels ###
label-badge-background-color: "#3E4C6C"
label-badge-red: "#252D40"
### Cards ###
paper-card-background-color: "#252D40"
### Toggles ###
paper-toggle-button-checked-button-color: "#FEB221"
paper-toggle-button-checked-bar-color: "#FECA67"
paper-toggle-button-unchecked-button-color: "#6E81AA"
paper-toggle-button-unchecked-bar-color: "#3E4C6C"
### Table row ###
I had to delete three (of just the naffer ones) to get it under the 32k limit.
ITLogic
(Chris)
January 28, 2020, 3:38am
37
Hey,
hijack it all that you guys want. I enjoy seeing what everyone think about stuff. That is how we all learn. Here is what Im looking at right now.
ITLogic
(Chris)
January 28, 2020, 3:39am
38
sorry for the screen grab.
finity
January 29, 2020, 1:11am
39
And you are on the latest version of HA?
how do you have zwave installed now? UI or yaml?
You should definitely have more stiff there:
Do you have your zstick inserted into the PI?
And do you see any entities in the states page that starts with “zwave.___”?
firstof9
(firstof9)
January 29, 2020, 5:36pm
40
Maybe Advanced Features
is toggled off for his profile?
finity
January 30, 2020, 4:08am
41
I don’t think that would cause it. I just turned off advanced mode and my zwave control panel stuff is all still there.
firstof9
(firstof9)
January 30, 2020, 12:24pm
42
Shot in the dark
Only other thing I could think of is the frontend install via pip might have gone wacky or and ad blocker is messing it up.
