I would like to setup a shelly plug with a heater … maybe in summer a small air condition if I export more than 300w to the grid. I dont get money for export and it make sense to use the energy for heating or cooling.
I get from the tasmota the Power of each phase. My Plant fires to one Phase. The messured power which I have to pay is the sum of all 3 phases. The produced Power is measured as neg. Value.
So if the Sum of L1/l2/L3 is negative, I have the value which is interesting for me. If that neg. Sum is greater than 300W the Plug should be powered on if it goes less then 10W it shoud go down.
in theory a easy job for Home assistent. But for me to big. Hope somebody here could help me out.
sure …but I wait for the arrive of the shally plug
what I have are the entities of the power
[sensor.tasmota_sm_36_7_0] Power L1 (w)
[sensor.tasmota_sm_56_7_0] Power L2 (w)
[sensor.tasmota_sm_76_7_0] Power L3 (w)
and as well the sum of the Power. But I am not sure if I get a negative value there !
[sensor.tasmota_sm_16_7_0]
I’ve just done that recently. In fact, I fitted the Shelly 1PM inside the heater. I use the Visual editor for the configuration of the Automation, however, the yaml looks like this.
its running … but I have a small problem. After the shelly is off and the trigger comes again, it takes more than five minutes to get th shelly back on.
Here is my code:
