I’m trying to remove an addon that I am working on, however the UI doesn’t let me. When I click “Uninstall” I get the following Supervisor log:
18-02-20 20:06:14 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 416, in start
resp = yield from self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web.py", line 325, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 93, in impl
return (yield from handler(request))
File "/usr/lib/python3.6/site-packages/hassio/api/security.py", line 41, in security_layer
return await handler(request)
File "/usr/lib/python3.6/site-packages/hassio/api/utils.py", line 33, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/lib/python3.6/site-packages/hassio/addons/utils.py", line 33, in wrap_check
return await method(addon, *args, **kwargs)
File "/usr/lib/python3.6/site-packages/hassio/addons/addon.py", line 563, in uninstall
if not await self.instance.remove():
File "/usr/lib/python3.6/site-packages/hassio/docker/utils.py", line 18, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/hassio/docker/interface.py", line 204, in _remove
"Remove docker %s with latest and %s", self.image, self.version)
File "/usr/lib/python3.6/site-packages/hassio/docker/addon.py", line 47, in version
return super().version
File "/usr/lib/python3.6/site-packages/hassio/docker/interface.py", line 45, in version
if self._meta and LABEL_VERSION in self._meta['Config']['Labels']:
TypeError: argument of type 'NoneType' is not iterable
I installed it by adding GitHub repo and it’s version doesn’t follow anything close to SemVer versioning. Is there any way for me to access the installed files over SSH and remove them by hand?
Thanks!
