Hi Gurus,
I recently fried my rpi3B+ where I was having hassio installed.
I decided to change platform and to install the supervised ha in a linux machine.
So far so good, all my zwave devises are connected and functionning.
However, I realised (docker stats) that the core_wave_js addon is using a lot of CPU.
$docker stats
CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
68f51562ae7b addon_core_zwave_js 136.13% 55.14MiB / 3.679GiB 1.46% 154kB / 152kB 47.3MB / 3.07MB 11
I was wondering if this is normal (I don’t recall such behaviour with my pi)? So I guess that there is something under the hood that is not working fine.
I have activated the low level logs and looked at them (docker logs). Except the message (Error: Invalid networkKey defined) which I believe is not meaning full I see nothing wrong:
$docker logs -f addon_core_zwave_js
[cont-init.d] structure.sh: executing...
[cont-init.d] structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[11:56:09] INFO: Successfully send discovery information to Home Assistant.
[11:56:12] INFO: Successfully send discovery information to Home Assistant.
[11:56:14] INFO: Successfully send discovery information to Home Assistant.
Can someone be kind enough to give me road of investigation.
Now, I can stop the docker with the supervised menu and everything is working fine up to the next boot.
Cheers
