hello everyone,
I´m needing a help I´m trying to instal addon of duckdns + let´s encrypt I´m following the instructions here https://home-assistant.io/addons/duckdns/ I made a duck dns account got my token and my domain fullfilled I set true to let´s encrypt but when I try to star gives me this:
Missing option keyfile in lets_encrypt for dictionary value @ data[‘options’]. Got {‘lets_encrypt’: {‘accept_terms’: True}, ‘token’: ‘sdfj-2131023-dslfjsd-12321’, ‘domains’: [‘my-domain.duckdns.org’]}
Port forward of 8123… depends. All the docs/videos say you don’t need to specify the port anymore when you have duckdns and ssl installed. I found in practice even though I had 443 forwarded to the Pi that I couldn’t get a connection unless I also had port 8123 forwarded and I had to specify :8123 or the web page would not connect.
I needed to port forward WAN 443 to LAN 8123 for the Hassio IP when connecting using the iOS app on iPhone using cellular data service. URL is https://my_domain.duckdns.org. (No 8123) So you probably need port forwarding for external access.
I tried to forward the port but its saying that this port is being already used (443) l, im trying to access mydomain.duckdns.org outside my network and its not happening. I have a modem that is also a router maybe its him that is blocking?
The port forwarding goes on the router. My biggest problem getting this to work is I kept trying to go to .COM instead of .ORG. Took me a couple days to figure that one out.
I’ve tried all combinations , I can enter inside my network but cant outside, I’ve tried to triggered aomething from hass.io to ifttt and didnt get any response, I think ita my router or my modem that is blocking something, wben I try to forward my port os given me that the lort is already being used 443, also if i dont fix my ip duck dns cant find my ip even inside my network
I had my port 443 to my xbox, thats why I was having problems, today I was able to send a trigger from my hassio to ifttt and my drive as a test, I still cant access my hass.io from my mobile outside my network and still didnt get my tv to turn on through ifttt and my GH i will revised my commands to see whats wrong
you’ll need to be forwarding port 8123 external to 8123 internal as well. When you set up LetsEncrypt, if 443 wasn’t forwarded to the Pi - that might explain the issue with LetsEncrypt as well. Did your certificate actually work?
I’m curious where to find all this information about port forwarding. I only forwarded 443 external to 8123 internal and I can access my system from the iOS app and a browser from the internet fine. My problem is internally on my network I can no longer ssh or samba in so my config is locked away now.
so still strugling to find a answer I forwarded the ports I was able to install duck dns, but I´m still not able to reach my hass.io outside my network, I know that in the tutorial says it´s not necessary to install let´s encrypt but i did anyway to try and gives me this message:
starting version 3.2.2
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Obtaining a new certificate
Performing the following challenges:
tls-sni-01 challenge for arissaraiva.duckdns.org
Waiting for verification…
Cleaning up challenges
Failed authorization procedure. arissaraiva.duckdns.org (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
IMPORTANT NOTES:
The following errors were reported by the server:
Domain: arissaraiva.duckdns.org
Type: connection
Detail: Timeout
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you’re using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
It´s not a problem with my domain, but I don´t know anymore what can I try, maybe it´s my router?
Have you tried refreshing/updating your IP on duckdns.org manually?
I’m guessing I somehow “broke” my ssh and samba because I never saw anything about turning them as you outline? Any guesses/leads on how to un-break them? I’m also seeing threads that talk about samba being possibly broken by one of the HA updates, particularly for Windows users (I’m on a Mac, and running Hass.io on my Pi), so maybe I didn’t break anything and its a larger problem? grasping at straws here…
I think I just got things working again, but I’m not sure exactly what the solution (or problem) was. I’m on the latest versions as of 2 days ago. Thankfully I could still access the front end, and even perform the latest Hass.io upgrade from that, but I would like to know how to use this terminal you’re referring to? (Mac OS Terminal? what commands?)
Uninstalled DuckDNS add-on
Uninstalled SSH
Uninstalled Samba
removed port forwarding
deleted the known_hosts file from my machine
rebooted Pi
started reinstalling add-ons
suddenly my Samba shares showed up and I can access them. added back other things I had removed.
I’m leaning toward problems somehow stored in my known_hosts file, as when I deleted that it seemed to resolve lot of scary SSH and browser “invalid certificate” errors I was seeing, as well as fixing SSH and Samba.
