Addon Grafana does not start and gives error when starting after installation
Problem/Motivation
My apologies if this isn’t the right place to post my issue. I’m unsure who needs to look into this.
I’ve installed the addon Grafana, but pushing the button ‘start’ I receive the error, see end of the post.
in Log Viewer all content (just [INFO]s) is disappeared and replaced by:
runtime/mfinal.go:193 +0x107 fp=0xc0000727e0 sp=0xc000072620 pc=0x13cb0c7 runtime.goexit() runtime/asm_amd64.s:1650 +0x1 fp=0xc0000727e8 sp=0xc0000727e0 pc=0x1423141 created by runtime.createfing in goroutine 1 runtime/mfinal.go:163 +0x3d: unknown")
Expected behavior
The addon gets started
Actual behavior
error received, see below.
Steps to reproduce
Not sure. I’ve just started with HASS this week, so all is done on recent official builds.
I am running Home Assistant OS 13.1 on VirtualBox 7.1.2. on Windows 10 home.
Home Assistant Core = 2024.10.1
I’ve used all suggested requirements, like 2 cpu’s, 4 GB memory and 32GB disk space of which 23 GB is free.
I’ve installed the following addons successfully: Studio Code Server, Log Viewer, InfluxDB, Mosquitto Broker
My ESP32 sensor readings are successfully push via MQTT and shown on my overview. The readings are in InfluxDB and I was ready to setup the graphs in Grafana.
Proposed changes
not available, I’m new to HASS.
Can't start addon_a0d7b954_grafana: 500 Server Error for http+docker://localhost/v1.45/containers/c1d5e3869bc1389ffd631c6d82ac528def80e7dba642fb57696a7376855a9803/start: Internal Server Error ("failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 2, stdout: , stderr: unexpected fault address 0xffffffffe36c4a9e fatal error: fault [signal SIGSEGV: segmentation violation code=0x1 addr=0xffffffffe36c4a9e pc=0x18a4f8e] goroutine 1 [running, locked to thread]: runtime.throw({0x38eaf3f?, 0x28?}) runtime/panic.go:1077 +0x5c fp=0xc000123da8 sp=0xc000123d78 pc=0x13eb69c runtime.sigpanic() runtime/signal_unix.go:875 +0x285 fp=0xc000123e08 sp=0xc000123da8 pc=0x1403705 google.golang.org/protobuf/proto.init() google.golang.org/protobuf/proto/decode.go:292 +0xe fp=0xc000123e18 sp=0xc000123e08 pc=0x18a4f8e runtime: g 1: unexpected return pc for google.golang.org/protobuf/proto.init called from 0xc000072638 stack: frame={sp:0xc000123e08, fp:0xc000123e18} stack=[0xc000122000,0xc000124000) 0x000000c000123d08: 0x0000000000000001 0x0000000000000001 0x000000c000123d18: 0x000000c000123d86 0x00000000014211b2 <runtime.systemstack+0x0000000000000032> 0x000000c000123d28: 0x000000c000123d68 0x00000000013eb9a5 <runtime.fatalthrow+0x0000000000000065> 0x000000c000123d38: 0x000000c000123d48 0x000000c0000061a0 0x000000c000123d48: 0x00000000013eb9e0 <runtime.fatalthrow.func1+0x0000000000000000> 0x000000c0000061a0 0x000000c000123d58: 0x00000000013eb69c <runtime.throw+0x000000000000005c> 0x000000c000123d78 0x000000c000123d68: 0x000000c000123d98 0x00000000013eb69c <runtime.throw+0x000000000000005c> 0x000000c000123d78: 0x000000c000123d80 0x00000000013eb6c0 <runtime.throw.func1+0x0000000000000000> 0x000000c000123d88: 0x00000000038eaf3f 0x0000000000000005 0x000000c000123d98: 0x000000c000123df8 0x0000000001403705 <runtime.sigpanic+0x0000000000000285> 0x000000c000123da8: 0x00000000038eaf3f 0x0000000000000028 0x000000c000123db8: 0xffffffffe36c4a9e 0x0000000000000001 0x000000c000123dc8: 0x000000c000123e00 0x000000000188d748 <google.golang.org/protobuf/reflect/protoregistry.init+0x0000000000000088> 0x000000c000123dd8: 0x000000c0000061a0 0x0000000000000009 0x000000c000123de8: 0x0000000000000000 0x0000000000000000 0x000000c000123df8: 0x000000c000123f30 0x00000000018a4f8e <google.golang.org/protobuf/proto.init+0x000000000000000e> 0x000000c000123e08: <0x00000000013fbf78 <runtime.doInit1+0x00000000000000d8> 0x000000c000072638 0x000000c000123e18: >0x00000000013be345 <runtime.newobject+0x0000000000000025> 0x0000000000000198 0x000000c000123e28: 0x00000000038ce680 0x00000001013f0101 0x000000c000123e38: 0x0000000000000000 0x00000000013f7125 <runtime.malg+0x0000000000000025> 0x000000c000123e48: 0x0000000000000000 0x0000000000000000 0x000000c000123e58: 0xd477d21c4031045d 0x00003625e5de49f3 0x000000c000123e68: 0x0000000000000000 0x000000c0000726b8 0x000000c000123e78: 0x00000000013f6cd1 <runtime.exitsyscallfast+0x0000000000000051> 0x00000000013f2038 <runtime.allocm+0x00000000000001b8> 0x000000c000123e88: 0x0000000001422d9a <runtime.asmcgocall+0x000000000000003a> 0x000000c0000061a0 0x000000c000123e98: 0x00000000013f2a3e <runtime.newm1+0x000000000000009e> 0x000000c0000726d8 0x000000c000123ea8: 0x00000000013f645c <runtime.reentersyscall+0x000000000000005c> 0x000000c0000061a0 0x000000c000123eb8: 0x000000c0000726f8 0x000000000141de0e <runtime.exitsyscall+0x000000000000012e> 0x000000c000123ec8: 0x000000c0000061a0 0x0000000200000003 0x000000c000123ed8: 0x000000c0000061a0 0x000000c000062500 0x000000c000123ee8: 0x00000000013b4b2b <runtime.cgocall+0x000000000000004b> 0x0000000001422d9a <runtime.asmcgocall+0x000000000000003a> 0x000000c000123ef8: 0x000000c000072730 0x00000000013b4b85 <runtime.cgocall+0x00000000000000a5> 0x000000c000123f08: 0x0000000003159920 0x0000000000000000 goroutine 2 [force gc (idle)]: runtime.gopark(0x0?, 0x0?, 0x0?, 0x0?, 0x0?) runtime/proc.go:398 +0xce fp=0xc000072fa8 sp=0xc000072f88 pc=0x13eef6e runtime.goparkunlock(...) runtime/proc.go:404 runtime.forcegchelper() runtime/proc.go:322 +0xb3 fp=0xc000072fe0 sp=0xc000072fa8 pc=0x13eedd3 runtime.goexit() runtime/asm_amd64.s:1650 +0x1 fp=0xc000072fe8 sp=0xc000072fe0 pc=0x1423141 created by runtime.init.6 in goroutine 1 runtime/proc.go:310 +0x1a goroutine 3 [GC sweep wait]: runtime.gopark(0x0?, 0x0?, 0x0?, 0x0?, 0x0?) runtime/proc.go:398 +0xce fp=0xc000073778 sp=0xc000073758 pc=0x13eef6e runtime.goparkunlock(...) runtime/proc.go:404 runtime.bgsweep(0x0?) runtime/mgcsweep.go:280 +0x94 fp=0xc0000737c8 sp=0xc000073778 pc=0x13d71d4 runtime.gcenable.func1() runtime/mgc.go:200 +0x25 fp=0xc0000737e0 sp=0xc0000737c8 pc=0x13cc125 runtime.goexit() runtime/asm_amd64.s:1650 +0x1 fp=0xc0000737e8 sp=0xc0000737e0 pc=0x1423141 created by runtime.gcenable in goroutine 1 runtime/mgc.go:200 +0x66 goroutine 4 [GC scavenge wait]: runtime.gopark(0xc00007a000?, 0x3d0a968?, 0x1?, 0x0?, 0xc0000071e0?) runtime/proc.go:398 +0xce fp=0xc000073f70 sp=0xc000073f50 pc=0x13eef6e runtime.goparkunlock(...) runtime/proc.go:404 runtime.(*scavengerState).park(0x533c4e0) runtime/mgcscavenge.go:425 +0x49 fp=0xc000073fa0 sp=0xc000073f70 pc=0x13d4889 runtime.bgscavenge(0x0?) runtime/mgcscavenge.go:653 +0x3c fp=0xc000073fc8 sp=0xc000073fa0 pc=0x13d4e3c runtime.gcenable.func2() runtime/mgc.go:201 +0x25 fp=0xc000073fe0 sp=0xc000073fc8 pc=0x13cc0c5 runtime.goexit() runtime/asm_amd64.s:1650 +0x1 fp=0xc000073fe8 sp=0xc000073fe0 pc=0x1423141 created by runtime.gcenable in goroutine 1 runtime/mgc.go:201 +0xa5 goroutine 18 [finalizer wait]: runtime.gopark(0x198?, 0x38ce680?, 0x1?, 0x1?, 0x0?) runtime/proc.go:398 +0xce fp=0xc000072620 sp=0xc000072600 pc=0x13eef6e runtime.runfinq() runtime/mfinal.go:193 +0x107 fp=0xc0000727e0 sp=0xc000072620 pc=0x13cb0c7 runtime.goexit() runtime/asm_amd64.s:1650 +0x1 fp=0xc0000727e8 sp=0xc0000727e0 pc=0x1423141 created by runtime.createfing in goroutine 1 runtime/mfinal.go:163 +0x3d: unknown")
You can ask for assistance here, but actually reporting an issue is done here:
Thanks for the info.
I’ve installed yesterday evening the new Home Assistant Core 2024.10.2 which got released. The update didn’t help anything.
After letting the machine run the entire night, strangely enough I could start the addon this morning.
Beats me what fixed it, it seems some processes aren’t aligned or something.
