chrisgrou
(Chris Grou)
January 23, 2021, 8:03pm
14
terryhonn
(Terry Honn)
January 23, 2021, 8:39pm
15
A bit off topic, perhaps, but I’m not a themer or css guru…could you tell me how you’re using the font-variant small-caps globally for your Lovelace font?
Thanks in advance!
chrisgrou
(Chris Grou)
January 23, 2021, 9:27pm
16
I don’t know if it can be done globally, I do it per card or sometimes (case in point), per entity. Most times this is enough:
style: |
ha-card {
font-variant: small-caps;
I can’t seem to figure out why my numberbox-card suddenly won’t render correct on my phone. It’s correct everywhere else, only icons on all numberbox-cards affected. Reset the HA app on my phone as well as reset cache in two browsers used in case a change had just not taken effect through the browsers. Still no change.
Example through Chrome:
Same numberbox-card through companion app on Android:
Icon is there if I open the entity through companion app:
Nothing fancy in the code:
- entity: input_number.temperatur_stue
name: Stue Mill når hjemme
type: 'custom:numberbox-card'
- entity: input_number.temperatur_stue_borte
name: Stue Mill andre status
- entity: input_number.temperatur_soverom
name: Soverom radiator når hjemme
- entity: input_number.temperatur_soverom_borte
name: Soverom radiator andre status
I also attempted to force the original mdi icon adding it through “icon:”, but that didn’t show anything either.
Anyone got ideas? Or similar issues?
htmltiger
(Htmltiger)
February 10, 2021, 3:36pm
19
I have just made some changes in state-badge so please update and see if that helps.
Also make sure you running home assistant version 2021.2.1 or newer as it may fix the issue
htmltiger:
2021.2.1
Sorry, I should have found the issue on Github. Impressive response time btw
Issue resolved through.
Installed updated card. Reset cache. No change.
Updated from 2021.1.5 to 2021.2.2. Reset cache. Solved.
stevoh6
(StevoH)
November 7, 2021, 7:59pm
21
@chrisgrou ,could you please share yours code? It looks awesome, something what I want for long time, but I have no idea where to start. Thx
chrisgrou
(Chris Grou)
November 29, 2021, 4:26pm
22
I tried to remove some debug code, I hope I didn’t break anything.
The lovelace card is:
cards:
- type: entities
entities:
- entity: input_number.water_heater_duration
type: custom:numberbox-card
icon: false
speed: 250
border: false
style: |
.grid-left {
font-size: 20px !important;
font-weight: 300 !important;
.cur-num {
font-size: 32px !important;
font-weight: 600 !important;
icon: mdi:water-boiler
title: Water Heater
style: |
#states {
padding: 10px 20px !important
ha-card {
.card-header {
padding: 10px 8px !important;
- cards:
- color: var(--st-mode-background, var(--secondary-background-color))
color_type: card
entity: input_select.water_heater_state
show_icon: true
icon: mdi:power
state:
- color: '#8a8a8a'
spin: false
styles:
icon:
- color: white
name:
- color: white
value: 'Off'
value: 'Off'
operator: '!='
styles:
icon:
- color: var(--secondary-text-color)
name:
styles:
card:
- height: 50px
name:
- font-size: 14px
- padding-bottom: 0px
tap_action:
action: call-service
service: input_select.select_option
service_data:
entity_id: input_select.water_heater_state
option: 'Off'
type: custom:button-card
style: |
ha-card {
--st-font-size-xl: 60px;
--st-font-size-m: 16px;
--st-spacing: 4px;
color_type: card
show_icon: true
icon: mdi:fire
state:
- color: '#f05454'
styles:
icon:
- color: white
name:
- color: white
value: Heat
value: Heat
operator: '!='
styles:
icon:
name:
styles:
card:
- height: 50px
- color: '#03a9f4'
name:
- font-size: 14px
tap_action:
service_data:
option: Heat
style: |
ha-card {
--st-spacing: 4px;
color_type: card
show_icon: true
icon: mdi:alarm
state:
- color: '#5eaaa8'
styles:
icon:
- color: white
name:
- color: white
value: Schedule
value: Schedule
operator: '!='
styles:
icon:
name:
styles:
card:
- height: 50px
- color: '#03a9f4'
name:
- font-size: 14px
tap_action:
service_data:
option: Schedule
style: |
ha-card {
--st-spacing: 4px;
type: horizontal-stack
styles:
card:
- '--keep-background': 'true'
- type: custom:time-picker-card
entity: input_datetime.water_heater_schedule_time
hour_mode: 24
hour_step: 1
minute_step: 1
second_step: 5
name: 'Scheduled to run at:'
layout:
embedded: false
align_controls: center
hide:
icon: true
style: |
ha-card {
font-size: 14px !important;
:host {
--tpc-elements-background-color: #5eaaa8 !important;
--tpc-text-color: white !important;
link_values: false
type: custom:stack-in-card
mode: vertical
keep:
background: true
border_radius: true
box_shadow: false
margin: true
outer_padding: true
The automations:
[Water heater] switch on from button
alias: '[Water heater] switch on from button'
description: ''
- platform: state
to: Heat
condition: []
- service: switch.turn_on
entity_id:
- switch.water_heater
[Water heater] switch off from button
alias: '[Water heater] switch off from button'
description: ''
- platform: state
to: 'Off'
condition: []
- service: switch.turn_off
entity_id: switch.water_heater
[Water heater] set mode to schedule from button
alias: '[Water heater] set mode to schedule from button'
description: ''
- platform: time
at: input_datetime.water_heater_schedule_time
- condition: state
state: Schedule
- service: input_select.select_option
option: Heat
[Water heater] refresh button when device is on
alias: '[Water heater] refresh button when device is on'
description: ''
- platform: state
to: 'on'
condition: []
option: Heat
[Water heater] heat water for specified time
alias: '[Water heater] heat water for specified time'
description: ''
- platform: state
to: 'on'
condition: []
- delay: '{{ states(''input_number.water_heater_duration'') | multiply(60) | int }}'
Helpers:
input_number.water_heater_duration (min:1, max: 60, step: 1)
input_boolean.water_heater_scheduled
input_select.water_heater_state (options: Heat, Off, Schedule)
SteveDinn
(Steve Dinn)
April 13, 2022, 4:45pm
23
I crafted up this set of buttons using paper-buttons-row
. They can increment or decrement the volume of my receiver by 1 or 5 dB, or mute / unmute it.
type: entities
entities:
- entity: input_number.livingroom_amp_volume
- type: custom:paper-buttons-row
buttons:
- icon: mdi:numeric-5-box-outline
tooltip: Volume down by 5
tap_action:
service: script.change_volume
service_data:
entity_id: input_number.livingroom_amp_volume
increment: -5
- icon: mdi:numeric-1-box-outline
tooltip: Volume down by 1
tap_action:
service_data:
increment: -1
- icon: >-
{{ iif(is_state_attr('media_player.livingroom_amp', 'is_volume_muted',
true), 'mdi:volume-high', 'mdi:volume-mute') }}
tooltip: Mute / Unmute
tap_action:
service: script.toggle_mute
service_data:
entity_id: media_player.livingroom_amp
tooltip: Volume up by 1
tap_action:
service_data:
increment: 1
tooltip: Volume up by 5
tap_action:
service_data:
increment: 5
And the server-side scripts. I had to use scripts because I couldn’t get the template parameters to work properly with the paper-buttons-row
card.
script:
toggle_mute:
alias: Toggle Mute
mode: queued
icon: mdi:volume-mute
fields:
entity_id:
description: A media_player entity that can be muted and unmuted
required: true
selector:
entity:
domain: media_player
- service: media_player.volume_mute
entity_id: "{{ entity_id }}"
is_volume_muted: "{{ not is_state_attr(entity_id, 'is_volume_muted', true) }}"
change_volume:
alias: Change Volume
mode: queued
icon: mdi:volume-high
fields:
entity_id:
name: Volume input_number
description: An input_number entity that corresponds to the volume of a media_player
required: true
selector:
entity:
domain: input_number
increment:
description: A integral value by which to adjust the volume
required: false
default: 1
selector:
number:
min: -10
max: 10
step: 1
unit_of_measurement: dB
mode: slider
value: "{{ min(20, max(-80, (states(entity_id) | int) + (increment |int))) }}"
zzuyee
(zzuyee)
December 21, 2022, 2:41am
25
Hi I followed the instruction and saved the numberbox-card.js into config/www folder. But I am getting “Custom element doesn’t exist: numberbox-card” in the card.
- type: entities
entities:
- type: custom:numberbox-card
entity: timer.rodi_water
icon: mdi:fire
service: timer.start
param: duration
state: duration
min: 0
max: 999999
step: 60
unit: time
htmltiger
(Htmltiger)
December 21, 2022, 3:10am
26
Have you done this?
Manually add numberbox-card.js
to your <config>/www/
folder and add the following to the configuration.yaml
file:
lovelace:
resources:
- url: /local/numberbox-card.js?v=1
type: module
jayjay
(JJ)
December 25, 2022, 11:53am
28
Got the number box running but, got stuck a bit.
I use it to set a light on delay after sunset, but I would love to set the delay and then see in the seecondary info of the button the real time it is set to, but that sensor info I just cannot get to be displayed, so how? Please
This is what I have:
border: true
entity: input_number.auto_light_minutes
secondary_info: >-
Licht aan: <b style="color:green">
%sensor.auto_light_start:attributes:timestamp </b>
unit: time
SteffenDE
(Steffen Maurer)
April 18, 2023, 5:36pm
29
Hi, great work.
Could I use the card to change timer duration without starting the timer with every change?
Here is my code from the examples:
card_mod:
style: |
ha-card {
background: none;
border: none;
box-shadow: none;
entity: timer.timer_welcomelight_std
icon: false
border: false
param: duration
state: duration
min: 0
max: 3600
step: 300
unit: timehm
Thanks, Steffen
htmltiger
(Htmltiger)
April 18, 2023, 5:57pm
30
There is no service to change just the duration,
try something like this:
- platform: state
entity_id: input_number.duration_in_seconds # this will trigger on any change of the input number
- service: timer.start
entity_id: timer.your_timer_here
duration: "{{ states('input_number.duration_in_seconds') }}"
- service: timer.cancel
entity_id: timer.your_timer_here # if you dont want the timer to start whenever you change the duration.
Please don’t share pictures of text. Paste and format the text. See point 11 here .
Now I’m going to ignore that advice to show you this:
[Screenshot_2021-05-17 Timer]
See how the documentation for the timer option duration says “integer or time”?
That means no templates, and no helpers.
However, what you want to do could be accomplished with an automation as the timer start service does allow templating of the duration. However this will start the timer whenever the duration is changed. If …
SteffenDE
(Steffen Maurer)
April 18, 2023, 6:11pm
31
OK thank you, so I have to use a input_number helper for the numberbox-card and use the value if I start the timer from my script.
Johnyboy9
(Johannes Löwen)
December 2, 2023, 5:05pm
32
this is my card:
entity: number.riro_kellervorrat_brot
icon: false
unit: ' Stück'
secondary_info: 'Letzter Kauf: %input_datetime.riro_kellervorrat_brot_letzter_kauf:state'
moreinfo: input_datetime.riro_kellervorrat_brot_letzter_kauf
border: true
“input_datetime.riro_kellervorrat_brot_letzter_kauf” is a date in format YYYY-MM-DD. Is it possible to format this in DD-MM-YYYY without using a template sensor?
Faecon
(Jo)
January 28, 2024, 7:27am
33
entity: input_number.keuken_vaatwas_ingevenaantalblokjes
service: script
icon: false
picture: false
border: false
card_mod:
style: |
:host {
padding-top: 35px;
padding-right: 4px;
can I run a script (service ?)
I want a “counter.keuken_vaatwas_vaatwasblokjes” increase or decrease by 1.
And can I have the same number as the counter in the middle ?
did you get it running? I’m having exactly the same issue (newbie, I guess…!)…
Thanks!
Installed the file in config/www (created the folder and pasted the file), and added the lines to configuration.yaml
lovelace:
resources:
type: module
and getting the “custom element does not exist: numberbox-card”
