Hi, I want to set up a new HA. I’m using an Odroid N2 with OS Installation. I followed these instructions and installed the OS on a eMMC module. ODROID - Home Assistant.
HA is running, so far, so good. But if I want to install addons I have a problem. If I go to the addon store and install an addon (e.g. SSH & Web Terminal) it seems to be installed. But is I go back to the addon store nothing is listed.
If I install an addon and open the configuration everything looks normal, but if I change something, e.g. add a password and click save, I get the message “There is no configuration for this addon”.
If I activate all options, like Watchdog and automatic update, and click start, every option gets deactivated. But in case of the SSH terminal it is shown in the sidebar and if I click on it it seems to work.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: SSH & Web Terminal
SSH & Web Terminal access to your Home Assistant instance
Add-on version: 13.0.0
You are running the latest version of this add-on.
System: Home Assistant OS 9.4 (aarch64 / odroid-n2)
Home Assistant Core: 2022.12.8
Home Assistant Supervisor: 2022.12.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-user: starting
s6-rc: info: service init-ssh: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-docker: starting
s6-rc: info: service init-docker successfully started
s6-rc: info: service init-mosquitto successfully started
s6-rc: info: service init-mysql successfully started
[12:09:13] NOTICE: Session sharing has been disabled!
s6-rc: info: service init-user successfully started
s6-rc: info: service ttyd: starting
s6-rc: info: service ttyd successfully started
[12:09:13] INFO: Starting the ttyd daemon...
[12:09:13] WARNING:
[12:09:13] WARNING: Logging in with a SSH password is security wise, a bad idea!
[12:09:13] WARNING: Please, consider using a public/private key pair.
[12:09:13] WARNING: What is this? https://kb.iu.edu/d/aews
[12:09:13] WARNING:
[12:09:13] NOTICE: RSA host key missing, generating one...
Generating public/private rsa key pair.
Your identification has been saved in /data/ssh_host_rsa_key
Your public key has been saved in /data/ssh_host_rsa_key.pub
The key fingerprint is:
SHA256:9WEmBhcmevdg1OiYydijwmrTaNjKPAHIfCfoKiyzLoQ root@a0d7b954-ssh
The key's randomart image is:
+---[RSA 3072]----+
***removed***
+----[SHA256]-----+
[12:09:15] NOTICE: ED25519 host key missing, generating one...
Generating public/private ed25519 key pair.
Your identification has been saved in /data/ssh_host_ed25519_key
Your public key has been saved in /data/ssh_host_ed25519_key.pub
SHA256:VX05bvrFBe+pU1fVOs88fTV4674auO9JVtXSg47Fwns root@a0d7b954-ssh
+--[ED25519 256]--+
***removed***
+----[SHA256]-----+
s6-rc: info: service init-ssh successfully started
s6-rc: info: service sshd: starting
s6-rc: info: service sshd successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[12:09:17] INFO: Starting the SSH daemon...
Server listening on 0.0.0.0 port 22.
Server listening on :: port 22.
This is just an example with the SSH addon, but I have similar issues with any addon
