Hi everyone,
I’m reaching out with a problem I can’t seem to reproduce the cause of.
Lately, I’ve noticed significant slowdowns and occasional server restarts in my system. I have a notification set up to alert me when there’s a spike in memory consumption over a certain period. This was initially due to a memory leak issue I had in the past, which I managed to fix with an update. The system worked fine for a while after that.
Now, I’ve run into a new challenge. I know there are sensors available for each addon, including one for RAM usage (sensor.*_memory_percent). However, this sensor no longer updates and remains stuck at 0. Previously, I’m certain these sensors updated in sync with the addon usage, but now they don’t.
Because of this, I’m unable to identify which addon is causing abnormal memory consumption, making it hard to diagnose the issue.
Has anyone experienced a similar problem or have suggestions on how to fix this? Any help would be greatly appreciated!
Thanks!
