This add-on allows you to use the Raspberry Pi a3s a hotspot to connect the different devices directly to the hass.io network without going through the router.
Installation
To use this repository with your own Hass.io installation please follow the official instructions on the Home Assistant website with the following URL:
https://github.com/davidramosweb/hassio-addons
Configuration
The available configuration options are as follows (this is filled in with some example data):
Note: This is just an example, donât copy and paste it! Create your own!
Conflicts
To prevent the addon stop working after a few minutes, you must disable NetworkManager for wlan0.
You can use the SSH & Web Terminal addon with the option âProtection modeâ disabled and run the following command:
Hi David, congratulations for this, but I would like to have it going through the router, like a access point, can you show me how to do it? Thank you very much.
Hello again, I just installed it. The only problem is that after the reboot and connecting into the cable, I am no longer able to connect to the GUI. I tried cable and wifi, it saw in both cases it is reachable via ping but not from the browser.
I am not sure why this happened as the plugin was not started, unless it was set to start with the boot, but I am 100% sure I didnât do it.
I had the chance to set the ssid and password but it is not broadcasting the SSID. Samba still works.
I wonder if this has something to do with the DNS plugin I also have installed.
Hi! Great work with this AddOn. It is the perfect solution for small houses to increase security without more gear. I need some help to fix some stability issues: I use it to control Shelly devices and it works well, but sometimes some devices go offline for no apparent reason. I am using the DHCP server offered in the store to assign stati IPs to devices. Do you think that might be the issue?
Thank you!
Hi, I understand that the hotspot network is closed and add no access to internet, but if the HA server (Pi3 in my case) is also wired to the rooter, does it conserve its internet access ?
Great add-on, kinda hope this could just end up in the community add-ons repo.
Wondering two things:
â do you know if this plays well with the offical DHCP Server add-on?
â have you considered allowing MAC address filtering in your add-on?
This would just allow a smidge of extra security for networks set up with this. It really just would require adding an optional config boolean for hostapdâs âmacaddr_aclâ, and two optional lists for âaccept_mac_fileâ and âdeny_mac_fileâ that make the respective files when entered in. Orrrrrr they could just be optional strings pointing to a file the user makes in their /config/ directory for Hass.
I know MAC address filtering is no substitute for making a good damn password anyway, but since the Pi only supports WPA2 anyway, any extra obstacles to pop in the way of bored, mischievous local script kiddies is appreciated (especially by those of us in, um, crowded wifi environments like apartment buildings )
I also got âexit code 2â and fixed it by removing the version numbers from sudo and networkmanager. Thanks lordrobert. Iâm running on a Pi4 with the firmware updated recently in 2021.
I didnât install from git, that didnât allow me to fix the version numbers. But i followed the instructions here: https://developers.home-assistant.io/docs/add-ons/tutorial by downloading a copy of https://github.com/davidramosweb/hassio-addons/tree/master/hassio-hostapd to my addons directory. Then âreloadâ as instructed in the tutorial from the Add-ons page and it shows up as a local repository.
Edit the Docker file to remove the version numbers, so you get this line:
Then from home assistant add-ons page for this add-on, just click âInstallâ and it worked for me.
I havenât yet tried to add a wifi device yet, but at least the service starts and will start on boot. I just have a couple of cheapy esphome thermometers but theyâre wifi, and i have no wifi out there, so the remote (hardwired) Pi out there will hopefully be able to read the temperature from those wifi devices.
For anyone still trying to get this work, I submitted PR16 to fix a few issues and add a few features - you could download that fork and install as a local add-on as itâs still not been approved.
Iâve also created a new add-on inspired by this, which adds extra functionality (DHCP server, hidden or visible SSID, MAC address filtering, currently testing internet access for clients).
Home Assistant 2023.8.2
Supervisor 2023.08.1
Operating System 10.4
Frontend 20230802.0 - latest
23-08-15 16:24:29 WARNING (SyncWorker_3) [supervisor.addons.validate] Add-on config âdevicesâ use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of Hassio Hostapd
23-08-15 16:24:29 WARNING (SyncWorker_3) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Hassio Hostapd
