I am new to the world of home assistant. After trying it out on my Synology nas i found the add on intergration in no longer possible on it. So i bought myself on pi4 4gb with a 32 gb sd card and followed the installation procedure. Now the addon store is available but it is in fact emtpy. Trying to add the repositories manualy resulted in the error the the repositori already excists.
I have also bought an other sd card because i read that sometimes strange errors occure due to an faulty sdcard, but that did not help unfortunatly.
I’ve also tried multiple versions of the HAOS and the result was the same everytime.
I looked into the logfile and there are a few errors but i have no understanding what to do with this. So now i was hoping that there is someone that can make sence of logfile and could/would tell me what steps i should take to solve the problem.
22-12-14 16:21:00 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0 - 172.30.32.4
22-12-14 16:21:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
22-12-14 16:21:01 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
22-12-14 16:21:01 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-12-14 16:21:01 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_multicast application
22-12-14 16:21:02 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
22-12-14 16:21:02 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-12-14 16:21:04 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
22-12-14 16:21:04 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version 2022.12.5
22-12-14 16:21:04 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
22-12-14 16:21:04 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.4 / BootSlot A
22-12-14 16:21:04 INFO (SyncWorker_1) [supervisor.docker.interface] Starting homeassistant
22-12-14 16:21:04 WARNING (SyncWorker_0) [supervisor.store.data] No repository information exists at /data/addons/git/5c53de3b
22-12-14 16:21:04 WARNING (SyncWorker_0) [supervisor.store.data] No repository information exists at /data/addons/git/a0d7b954
22-12-14 16:21:04 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-12-14 16:21:04 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-12-14 16:21:04 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-12-14 16:21:04 ERROR (MainThread) [supervisor.store.git] Integrity check on /data/addons/core failed: Cmd('git') failed due to: exit code(128)
cmdline: git fsck
stderr: 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'.
22-12-14 16:21:04 ERROR (MainThread) [supervisor.store] Can't load data from repository core due to
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RESET - ContextType.STORE / core
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
22-12-14 16:21:04 ERROR (MainThread) [supervisor.store.git] Integrity check on /data/addons/git/a0d7b954 failed: Cmd('git') failed due to: exit code(128)
cmdline: git fsck
22-12-14 16:21:04 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/hassio-addons/repository due to
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RESET - ContextType.STORE / a0d7b954
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
22-12-14 16:21:04 ERROR (MainThread) [supervisor.store.git] Integrity check on /data/addons/git/5c53de3b failed: Cmd('git') failed due to: exit code(128)
cmdline: git fsck
22-12-14 16:21:04 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/esphome/home-assistant-addon due to
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RESET - ContextType.STORE / 5c53de3b
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
22-12-14 16:21:04 WARNING (SyncWorker_2) [supervisor.store.data] No repository information exists at /data/addons/git/5c53de3b
22-12-14 16:21:04 WARNING (SyncWorker_2) [supervisor.store.data] No repository information exists at /data/addons/git/a0d7b954
22-12-14 16:21:04 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
22-12-14 16:21:04 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-12-14 16:21:04 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-12-14 16:21:04 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-12-14 16:21:04 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-12-14 16:21:04 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-12-14 16:21:04 INFO (MainThread) [__main__] Running Supervisor
22-12-14 16:21:04 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-12-14 16:21:04 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-12-14 16:21:04 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-12-14 16:21:04 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-12-14 16:21:04 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-12-14 16:21:04 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-12-14 16:21:04 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-12-14 16:21:04 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-12-14 16:21:04 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-12-14 16:21:04 INFO (MainThread) [supervisor.host.info] Updating local host information
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-12-14 16:21:04 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-12-14 16:21:04 INFO (MainThread) [supervisor.host.services] Updating service information
22-12-14 16:21:04 INFO (MainThread) [supervisor.host.network] Updating local network information
22-12-14 16:21:04 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-12-14 16:21:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-12-14 16:21:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-12-14 16:21:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
22-12-14 16:21:05 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-12-14 16:21:05 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
22-12-14 16:21:05 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-12-14 16:21:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-12-14 16:21:06 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-12-14 16:21:06 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-12-14 16:21:06 INFO (MainThread) [supervisor.resolution.fixups.store_execute_reset] Reset corrupt Store: core
22-12-14 16:21:06 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
22-12-14 16:21:18 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-12-14 16:21:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-12-14 16:21:21 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-12-14 16:21:21 WARNING (MainThread) [supervisor.store.git] There is already a task in progress
22-12-14 16:21:21 WARNING (SyncWorker_3) [supervisor.store.data] No repository information exists at /data/addons/git/5c53de3b
22-12-14 16:21:21 WARNING (SyncWorker_3) [supervisor.store.data] No repository information exists at /data/addons/git/a0d7b954
22-12-14 16:21:21 WARNING (SyncWorker_1) [supervisor.store.data] No repository information exists at /data/addons/git/5c53de3b
22-12-14 16:21:21 WARNING (SyncWorker_1) [supervisor.store.data] No repository information exists at /data/addons/git/a0d7b954
22-12-14 16:21:21 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
22-12-14 16:21:31 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-12-14 16:23:16 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Failed to connect to github.com port 443 after 130098 ms: Operation timed out
22-12-14 16:23:16 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
