Addon-store issue not loading
hi there all, I am getting a addon store issue when going to it. Please if there is anyone with this issue and knows what caused it and how to sort out. Thanks in advance
192.168.0.160:8123 says
Failed to fetch add-on info
Log I get this error below
System log
File “/usr/src/hassio/hassio/api/addons.py”, line 158, in list
ATTR_NAME: repository.name,
File “/usr/src/hassio/hassio/store/repository.py”, line 41, in name
return self.data.get(ATTR_NAME, UNKNOWN)
File “/usr/src/hassio/hassio/store/repository.py”, line 36, in data
return self.sys_store.data.repositories[self.slug]
KeyError: ‘0ff24803’
19-05-13 10:18:22 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-05-13 10:31:13 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/src/hassio/hassio/api/security.py”, line 144, in token_validation
File “/usr/src/hassio/hassio/api/utils.py”, line 32, in wrap_api
answer = await method(api, *args, **kwargs)
19-05-13 10:31:21 ERROR (MainThread) [aiohttp.server] Error handling request
resp = await task
19-05-13 10:48:27 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-05-13 11:08:35 INFO (MainThread) [hassio.api.security] /homeassistant/info access from cebe7a76_hassio_google_drive_backup
19-05-13 11:08:35 INFO (MainThread) [hassio.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
19-05-13 11:18:28 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-05-13 11:43:43 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/notoriousbdg/hassio-addons repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/stefanlaheij/hassio-addons repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/esphome/hassio repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/fredrikbaberg/hassio-addons repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/vkorn/hassio-addons repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/danielwelch/hassio-addons repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/d8ahazard/Cast.bundle repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/bezmi/addon-phlex/ repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/pantomax/haxio repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/AndBobsYourUncle/hassio-addons/ repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://www.github.com/HerrHofrat/hassio-addons repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-05-13 11:43:43 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/marthoc/hassio-addons repository
19-05-13 11:43:50 ERROR (MainThread) [hassio.utils.json] Can’t read json from /data/addons/git/0ff24803/repository.json: [Errno 2] No such file or directory: ‘/data/addons/git/0ff24803/repository.json’
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read repository information from /data/addons/git/0ff24803/repository.json
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/69bb46cb/dnsomatic/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/4f82ad90/tor/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/4f82ad90/motion/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/dasshio/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/git_pull/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/local_audio_player/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/rpi-rf-receiver/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/broadlink_s1c/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/hc-sr04/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/test/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 WARNING (MainThread) [hassio.store.data] Can’t read /data/addons/git/ab75e4fb/broadlink_s1c_2/config.json: required key not provided @ data[‘arch’]. Got None
19-05-13 11:43:50 INFO (MainThread) [hassio.store] Load add-ons from store: 82 all - 0 new - 0 remove
19-05-13 11:48:32 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-05-13 12:04:32 ERROR (MainThread) [aiohttp.server] Error handling request
I dunno.
Just got there fine on my RPi3B+ .
