I tried the approach described in Local Addon Testing.
- First I started " ‘Rebuild and Reopen in Container’" → container started successfully
- I got the root prompt.
- Then I executed “Start Home Assistant” from Command Panel
- It was hanging, so I stopped it and tried again.
- It was starting HA and wrote log files
- Then it hung and finally wrote the following to the log:
23-10-19 17:15:18 ERROR (SyncWorker_1) [supervisor.docker.manager] Can't start homeassistant: 500 Server Error for http+docker://localhost/v1.43/containers/4140fe2ed251abe1128fc516ffc87b8c2bbfa295e25bbe8560c9819b1320aa33/start: Internal Server Error ("path /tmp/supervisor_data/share is mounted on / but it is not a shared or slave mount"
What can be wrong here?
How can I solve it?
Thank you, Volkmar
