Addon to simplify complex yaml configuration using jinja2 templates
I recently needed to set something up in HA that required a lot of repeated config for lots of similar entities. That was made much simpler using a template instead of writing the plain config (and far less scope for copy/paste errors!).
I found lots of people asking how to use templates in the HA config but no really good answers, so I put together and addon that does exactly that and thought I’d post it here in case anyone else would find it useful.
Here’s a basic example that sets up two smart thermostate climate entities.
This gets saved as a *.yaml.jina file in the HA config folder and automatically compiled to a *.yaml file by the addon, which is then included by the main HA config yaml file.
{% set rooms = [
        "name": "Living Room",
        "id_prefix": "living_room",
        "kp": 100,
        "ki": 0.01,
        "kd": 2500
        "name": "Study",
        "id_prefix": "study",
        "kp": 100,
        "ki": 0.001,
        "kd": 1000
{% set presets = {
    "min": 7,
    "max": 25,
    "away": 7,
    "eco": 17,
    "sleep": 17,
    "comfort": 19,
    "boost": 21
climate:
  {% for room in rooms %}
  - platform: smart_thermostat
    name: {{ room.name }} Smart Thermostat
    unique_id: {{ room.id_prefix }}_smart_thermostat
    heater: switch.{{ room.id_prefix }}_heating
    target_sensor: sensor.{{ room.id_prefix }}_temperature
    ac_mode: False
    kp: {{ room.kp }}
    ki: {{ room.ki }}
    kd: {{ room.kd }}
    keep_alive: 00:01:00
    pwm: 00:25:00
    min_cycle_duration: 00:5:00
    {%- for preset in presets %}
    {{ preset }}_temp: {{ presets[preset] }}
    {%- endfor %}
    target_temp: {{ presets["away"] }}
    debug: true
  {% endfor %}
